only some copied instances are not following the correct orientation
  On 4/4/2023 at 2:16 PM, Jesper Rahlff said:
its because you are calculating your normals on the primitives in the normal sop. If you change that to calculate on the points it works correctly
If I change to point normals, the orientation is wrong. Yes they are all pointing in the same direction but it's the wrong direction. Each should conform to the direction where the primitive is facing, just like most copies do in the image in the first post.
