UpyopyoSky Posted October 20, 2023 Share Posted October 20, 2023 Hi, I installed image magick, in order to use an exporting mp4 flipbook. However, under a certain condition, exporting ffmpeg mp4 returns the error like a screenshot. Then I randomly had to change values of res or frame ranges, etc., to get through encode. If that is still not working, I have to choose Windows avi format. Thus, can anyone explain what's the exact reason and how to fix the problem? Are there a certain resolution limit and have to choose specific aspect ratios? Thanks! Quote Link to comment Share on other sites More sharing options...
Librarian Posted October 20, 2023 Share Posted October 20, 2023 (edited) @tagosaku Maybe issue its -> Have you install ffmpeg on Windows? ..check on google How to install on correct system environment variables(Path) Edited October 20, 2023 by Librarian Quote Link to comment Share on other sites More sharing options...
UpyopyoSky Posted October 21, 2023 Author Share Posted October 21, 2023 (edited) Yeah, the image magick is installed to Windows, then houdini configures it. That's my understanding. Small rez and simple scene have mostly succeeded to create mp4 videos, so want to know what condition causes encode error . Edited October 21, 2023 by tagosaku Quote Link to comment Share on other sites More sharing options...
samesami Posted October 21, 2023 Share Posted October 21, 2023 On 10/20/2023 at 4:38 AM, tagosaku said: Hi, I installed image magick, in order to use an exporting mp4 flipbook. However, under a certain condition, exporting ffmpeg mp4 returns the error like a screenshot. Then I randomly had to change values of res or frame ranges, etc., to get through encode. If that is still not working, I have to choose Windows avi format. Thus, can anyone explain what's the exact reason and how to fix the problem? Are there a certain resolution limit and have to choose specific aspect ratios? Thanks! Expand Check your image resolution. Try with the standard 1080*1920 and other standard resolution. Quote Link to comment Share on other sites More sharing options...
UpyopyoSky Posted December 2, 2023 Author Share Posted December 2, 2023 it seems that FFMPEG can take only even number resolutions, and odd number res crashes the output. For instance 1920 x 1200 should work but 1920 x 1201 does crash. Hopefully this info helps other artists, too! 1 Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 3, 2023 Share Posted December 3, 2023 This works fine in H20 btw Quote Link to comment Share on other sites More sharing options...
