Export mp4 error with ffmpeg by MPlay flipbook
UpyopyoSky
Hi, I installed image magick, in order to use an exporting mp4 flipbook. However, under a certain condition, exporting ffmpeg mp4 returns the error like a screenshot. Then I randomly had to change values of res or frame ranges, etc., to get through encode. If that is still not working, I have to choose Windows avi format.
Thus, can anyone  explain what's the exact reason and how to fix the problem? Are there a certain resolution limit and have to choose specific aspect ratios?
Thanks!
Yeah, the image magick is installed to Windows, then houdini configures it. That's my understanding. Small rez and simple scene have mostly succeeded to create mp4 videos, so want to know what condition causes encode error .
Edited by tagosaku
Thanks!
Check your image resolution. Try with the standard 1080*1920 and other standard resolution.
  • 1 month later...
