Gas Particle to Field issue...
Masoud
Hi guys,
As you can see in the image bellow, I tried to use the Gas Particle to Field  to affect the smoke by particles, but the problem is:
- When I connect the both solvers object inputs to the Smoke Object, it works fine.
- When I add and connect a "POP Object" as my pop solver object input, it doesn't works.
How can I fix it?
Thanks for helping.
Particle to Field_01.hipFetching info...
Thank you Tesan for the hip file, but I don't want to import the particles from outside of the DOPs. I would like to use it in the same way I showed in the image. So the problem is I can't read the velocity attribute (or maybe Geometry data) from the POP object, in the same DOP.
