Question about additive point position recursion in Vex
noc2
Hi;
I have come to see that one needs to use a wrangle inside a foreach loop to get an additive recursive operation. But I really need to know if I really need to do that. Let me present a scenario first:
Imagine there's a line with say, 5 points.
Using a Point Wrangle Sop, I want to:
  1. Rotate the first point 0 around its neighbor, which is 1.
  2. Then I want to rotate point number 1 and 0 in its just previously altered position around point number 2.
  3. Then I want to rotate point 0, 1 in their just previously altered position and 2 around point 3, and so on...
My problem is that I can't get the point wrangler to retrieve the altered point positions to work on inside a for() loop. The point() function simply returns the initial positions of the points :-/ Now, I got this to work inside a foreach loop, but when the point count reaches somewhere around 100, the cooking rate drops like crazy :( And for something as easy as this task, I found it overkill to use a foreach() sop inside a compiled block and such.
I would be more than grateful if someone could enlighten me on the very subject.
Many thanx in advance.
Cheers;
AJ
Hey there @konstantin magnus;
Thank you so much for your reply. I was keeping kinefx as a backup for this task as it provides a built-in parent-child relation between points, which is great! Thank you so much for the code, highly appreciated :)
I came across this mini tutorial on YT based on Geometry Nodes in Blender a while back:
So essentially, Geo Nodes is a one big VOP in itself. Here, he makes use of the repeat zone, which is a for-each loop basically, to roll the points upward. I kind of set this one as a challenge for myself, thinking that if this is easily doable in geometry nodes in a single network, maybe I could do it in a single wrangle... It turns out that although geo nodes is able to do an additive recursion, I found that that may not be entirely the case in Houdini, hence the reason I wanted to consult on the matter in od-force.
I also checked out Matt's CGwiki page and checked out his article where he first tackles unrolling a rolled up line geometry and then gets into the reverse of the prcedure, which is the exercise I gave myself :) Just wanted to see if I could get it done in a single point wrangle without having make use of a for-each sop without referring Matt's methodology directly and coming up with my own, no matter how clunky it may be :)
So basically, mu question is this; is it not possible to deform points and recursively deform those deformed points in Houdini?
Cheers;
AJ
