Arthur Spooner Posted February 21, 2024 Share Posted February 21, 2024 I've been away from Houdini for a while, and I'm having an issue with a FEM Setup. Following this tutorial at this point; the sphere simulates although in my scene (attachment) the sphere just simulates between frames 0-1 ? FEMSetup.hiplc Quote Link to comment Share on other sites More sharing options...
tamagochy Posted February 21, 2024 Share Posted February 21, 2024 FEM is outdated solver, try vellum its faster and better Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted February 22, 2024 Author Share Posted February 22, 2024 (edited) 7 hours ago, tamagochy said: FEM is outdated solver, try vellum its faster and better That may be so, but I still want to know why it's not working as it is in the tutorial ? Edited February 22, 2024 by Arthur Spooner Quote Link to comment Share on other sites More sharing options...
Librarian Posted February 22, 2024 Share Posted February 22, 2024 @Arthur Spooner here its a file that its posted on Web so you can see your mistake's . dfx_FEMfibers.hiplc Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted February 22, 2024 Author Share Posted February 22, 2024 I made some progress on this tutorial, although in the tutorial the femsolidobject is used but when I use that dopnet node I get a warning; there are 3042 triangles with nonpositive mass density there are 3042 triangles with nonpositive thickness What is the reason for this error with this dopnet node ? Although when I use the femhybridobject it works more similar to that in the tutorial, not exactly but close. Quote Link to comment Share on other sites More sharing options...
ryew Posted February 22, 2024 Share Posted February 22, 2024 As tamagochy said, it's an outdated system and a lot has changed within Houdini in the past 3+ years since that tutorial and it's very likely the DOP nodes have changed through the newer Houdini versions since then so things won't work the same as when that was recorded. I generally don't put much faith in Houdini DOP tutorials that are more than a couple versions old these days 1 Quote Link to comment Share on other sites More sharing options...
