SohailNordin Posted February 25 Share Posted February 25 So here's my geometry : And then after appending the convert line SOP : Now i want to basically "undo" this and go back to having faces (for context i'm feeding these primitives into a grain simulation to tear it). So i tried with the Polyfill set to triangles but it outputs an error. I've tried using the ends SOP, fuse SOP, polydoctor SOP, etc to fix it but it still won't patch the open triangles. Any advice on filling in the faces would be greatly appreciated. Thank you! Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 25 Share Posted February 25 I do not understand what you are trying to do here. You already have the "faces" before the convert line SOP, so use that for whatever you need to and use the lines for your sim if that is what you need. 1 Quote Link to comment Share on other sites More sharing options...
hannes603 Posted March 6 Share Posted March 6 wireframe_prim_curves_to_triangle_polys_vop.hip you can try something like that maybe Quote Link to comment Share on other sites More sharing options...
