VDB Meshing Without Intersections ?
Ultraman
19 hours ago, Atom said:
You can add attributes you want to keep during the conversion process, but that does double or triple your memory usage.
Thanks man , but is there any hip plz ?  , im not sure after promote what will be in the Convert process bcuz here i have same issues
As far as i know volumes and vdbs thats Something Impossible to do... The only way is what you did ... Creating seperate Volume grids but then you ll have those seperators. Why so you want to Turn it into vdb in the first place?
Edited by hannes603
