TheAdmira1 Posted April 22, 2008 Share Posted April 22, 2008 anyone using it? anyone have any info on it or where to start lookin for info? I have to take a renderman class next 1/4 and i really am not a fan of maya... so i want to look into taking it with H9 but i cant really find any info on it... thanks in advance... Quote Link to comment Share on other sites More sharing options...
chunkified Posted April 22, 2008 Share Posted April 22, 2008 hey there what kinda info are you looking for? Installation? Renderman specific? Usage? The odForce wiki has some good installation info and it's a breeze to integrate it with H9... Quote Link to comment Share on other sites More sharing options...
TheAdmira1 Posted April 22, 2008 Author Share Posted April 22, 2008 hey there what kinda info are you looking for? Installation? Renderman specific? Usage? The odForce wiki has some good installation info and it's a breeze to integrate it with H9... wats goin on? well my prof is a MFing Renderman god when it comes to maya... but he hasnt used it in H9 yet... so i guess im just asking... how? haha... i dnt know a damn thing about renderman, but before i jump into asking to have an independent study in renderman w H9 i was wondering what your experiences with it, and is there any info out there i can catch up on before jumping into it in a couple weeks... thanks again! Quote Link to comment Share on other sites More sharing options...
edward Posted April 22, 2008 Share Posted April 22, 2008 First, make sure you're not using Apprentice. RenderMan output is disabled in there. Second, make sure you have Renderman installed (see PrManSetup). Third, set up your scene in Houdini as usual, taking care to attach RenderMan (aka RSL) shaders/materials to your geometry instead of VEX ones. Forth, create a RenderMan ROP, set it up, render. Quote Link to comment Share on other sites More sharing options...
Jason Posted April 23, 2008 Share Posted April 23, 2008 If you're learning shader-writing, you might be interested in Mantra. Most of the same concepts and techniques apply in VEX as they do in RSL and Mantra is free to use with Apprentice. Try it:) Quote Link to comment Share on other sites More sharing options...
TheAdmira1 Posted April 23, 2008 Author Share Posted April 23, 2008 good deal... thanks guys! Quote Link to comment Share on other sites More sharing options...
deepblack Posted April 24, 2008 Share Posted April 24, 2008 so what is that mean? D04001 {WARNING} DspyName: couldn't find requested driver: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.179/bin/ri_shaders/d_houdini.dll R90011 {SEVERE} Can't open display image ip Quote Link to comment Share on other sites More sharing options...
pagefan Posted April 24, 2008 Share Posted April 24, 2008 Did you install the renderman connection for houdini using proto_install? I guess it's missing. Quote Link to comment Share on other sites More sharing options...
edward Posted April 24, 2008 Share Posted April 24, 2008 Make sure the that your $HOME/rendermn.ini contains the path to your display driver. Make sure it exists. If you've installed multiple display drivers, there might be multiple lines. Delete the old ones that you don't use. I think only the last specified path is used. Quote Link to comment Share on other sites More sharing options...
deepblack Posted April 25, 2008 Share Posted April 25, 2008 what 've done so far is below. please correct me if i am wrong in any part HOUDINI_DEFAULT_RIB_RENDERER=C:\Program Files\Pixar\RenderManProServer-13.5.2\bin\prman.exe HOUDINI_PATH=\C:\Program Files\Pixar\RenderManProServer-13.5.2\bin;& HOUDINI_RI_SHADERPATH=i am confused in here should it be " C:\Documents and Settings\user\Mydocuments\houdini9.1\ri_shaders" or " C:\Program Files\Side Effects Software\Houdini 9.1.179\bin\ri_shaders " or no need for this one i manage the scene lights,cam,obj,rop>renderman. and proto_install thing. then render. in my case renderman is 22 and it brings 3 choices to me which one should i choose. none of the choises works for me. in $home/rendermn.ini file. i delete everything. after each proto_installing,it is adding new lines. but i can't make it work. runtime error first,complaning abaout visual c++ runtime library.and the houdini console error massage,that i've mentioned before. so i am stuck. Quote Link to comment Share on other sites More sharing options...
deepblack Posted April 25, 2008 Share Posted April 25, 2008 i changed HOUDINI_DEFAULT_RIB_RENDERER to prman13.5.2 and HOUDINI_RI_SHADERPATH to C:\Program Files\Side Effects Software\Houdini 9.1.179\houdini\ri_shaders i can get renders in ip window,if i don't proto install anything. but if i don't do that i. i don't get any shader view in vops. it says you have to instal display driver.as soon as i do, this runtime error thing happens. what are your suggestions. Quote Link to comment Share on other sites More sharing options...
tikal Posted January 10, 2009 Share Posted January 10, 2009 i changed HOUDINI_DEFAULT_RIB_RENDERER to prman13.5.2and HOUDINI_RI_SHADERPATH to C:\Program Files\Side Effects Software\Houdini 9.1.179\houdini\ri_shaders i can get renders in ip window,if i don't proto install anything. but if i don't do that i. i don't get any shader view in vops. it says you have to instal display driver.as soon as i do, this runtime error thing happens. what are your suggestions. i have exaclty the same problem....once i have set the env var in the path for prman as i open houdini i can get render output in the framebuffer window...i think....there is written ip in the top left corner. when i use proto install to comunicate the display driver to houdini this is no more working. is this happening becouse of the path where is the display driver_? should i put the driver in another location instead of the documents windows folder? this thing is driving me mad!! thanks in advance Mat Quote Link to comment Share on other sites More sharing options...
