tayga Posted April 1, 2009 Share Posted April 1, 2009 my renders stop on certain frames. Render manta rop output driver returns : Error command exit code 11. I can not find anywhere in manual What does this code 11 mean. Please help. Im using Houdini 9.5 170 build on Ubuntu 8.04 64bit thanks Quote Link to comment Share on other sites More sharing options...
Jason Posted April 1, 2009 Share Posted April 1, 2009 my renders stop on certain frames. Render manta rop output driver returns : Error command exit code 11. I can not find anywhere in manual What does this code 11 mean. Please help. Im using Houdini 9.5 170 build on Ubuntu 8.04 64bit thanks This sounds like a bona fide crash. There are some things you do to track down the problem, but the most effective thing you can do is to download a later build of 9.5 from the HoudiniDownloads page and just try to render again. 9.5.170 is pretty old and it's quite likely they've fixed whatever problem you're running into. Good luck, Jason Quote Link to comment Share on other sites More sharing options...
tayga Posted April 2, 2009 Author Share Posted April 2, 2009 (edited) This sounds like a bona fide crash. There are some things you do to track down the problem, but the most effective thing you can do is to download a later build of 9.5 from the HoudiniDownloads page and just try to render again. 9.5.170 is pretty old and it's quite likely they've fixed whatever problem you're running into.Good luck, Jason Thanks for you reply, Jason. what is "bona fide crash"? I updated to 379 build but got this error again. I have no idea what exactly in my scene cosing this and what does this error mean. Edited April 2, 2009 by tayga Quote Link to comment Share on other sites More sharing options...
wiz4rd Posted October 22, 2010 Share Posted October 22, 2010 Thanks for you reply, Jason. what is "bona fide crash"? I updated to 379 build but got this error again. I have no idea what exactly in my scene cosing this and what does this error mean. Time to revive this rather old thread. I get the same error with the currently available 11.0.504 Apprentice build. Everything's running smooth, until I try to do anything point cloud related. In my case, I was trying to re-implement Peter Quint's Wet Map approach, and also trying out the Wetmap OTL from the Houdini Exchange, which is based on the former. My first guess were memory issues, but then again, 1) it's hard to believe that measly 1695 points (I already deleted all points that weren't considered wet) would eat up 6GB of RAM. 2) I rendered other scenes which were more memory intensive. 3) I kept an eye on the system monitor, which reached 1gig using IP, and was using merely 800MB when rendering to EXR. On the other hand, reducing the tile size from default 16 to 8 helped Mantra to render more frames -- 20 instead of 2--4 resp. 11, when literally everthing was cached to disk: fluid sim, particle fluid surface BGEOs, and of course the pointclouds -- before Mantra crashed stating "Command Exit Code: 11"... whatever that means. Cheers - wiz - P.S I can upload a scene file later, in case someone's interested in checking whether this "bug" is reproducable. Quote Link to comment Share on other sites More sharing options...
wiz4rd Posted October 22, 2010 Share Posted October 22, 2010 P.S I can upload a scene file later, in case someone's interested in checking whether this "bug" is reproducable. Here it is. The point clouds have to be created, first. Tried it, a few times. It crashes at various frames, here. Once already after frame 4, another time it renders fine to frame 20. Quote Link to comment Share on other sites More sharing options...
wiz4rd Posted October 23, 2010 Share Posted October 23, 2010 Here it is. The point clouds have to be created, first. Tried it, a few times. It crashes at various frames, here. Once already after frame 4, another time it renders fine to frame 20. File attached? pcloud-bug.hipnc Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted October 25, 2010 Share Posted October 25, 2010 I have the same problem in ubuntu 10.10 x64, H11.0.540; But with prman's ptfilter running from a shell node, have the same code 11 error; If i run the command from a standard ubuntu shell it works, but no inside a shell node;In windows works like a charm. Thanks Quote Link to comment Share on other sites More sharing options...
wiz4rd Posted October 25, 2010 Share Posted October 25, 2010 (edited) I have the same problem in ubuntu 10.10 x64, H11.0.540 Right, totally forgot... I'm on Ubuntu 10.04 x64, using Houdini 11.0.504. But that's interesting! Maybe it's got something to do with this particular Ubuntu build as it uses gcc4.4. (EDIT1) Just downloaded another build where gcc4.1 was used and will install it now. Then we'll see... (EDIT2) ... that loading the pointclouds doesn't work at all. At least, they're not visible when rendered. Maybe a build with a little more up to date gcc (4.3) ... Edited October 25, 2010 by wiz4rd Quote Link to comment Share on other sites More sharing options...
wiz4rd Posted October 25, 2010 Share Posted October 25, 2010 (EDIT2) ... that loading the pointclouds doesn't work at all. At least, they're not visible when rendered. Maybe a build with a little more up to date gcc (4.3) ... ... it doesn't work either. When I re-built the point cloud part of the shader, the wetmap did show up, but again, the render stopped after a couple of frames. Meanwhile I don't think that reverting back to an earlier gcc version -- even if I rebuild the shader -- would make any difference. That's really strange. Quote Link to comment Share on other sites More sharing options...
wiz4rd Posted October 29, 2010 Share Posted October 29, 2010 Finally, it works! Just had to wait for the 11.0.547 build to be available for apprentice users. Downloaded, installed, started, hit render ... 1 frame, 2 frames, 8 frames, 25 frames, ... 96 frames, and still rendering. Great! Quote Link to comment Share on other sites More sharing options...
edward Posted October 29, 2010 Share Posted October 29, 2010 FYI, daily (ie. all) builds are available to Apprentice users if you register for the free sidefx.com login. Once logged in, just go to Support > Download. Quote Link to comment Share on other sites More sharing options...
wiz4rd Posted October 31, 2010 Share Posted October 31, 2010 FYI, daily (ie. all) builds are available to Apprentice users if you register for the free sidefx.com login. Once logged in, just go to Support > Download. That's good to know. Thanks! Totally missed that one. I always thought the only way to download the apprentice version is via the "Download Apprentice" page. Well, you live and learn. Cheers - wiz - Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted April 17, 2013 Share Posted April 17, 2013 (edited) Hi, Now with 12.5.371 and 12.5.316.22 I have the same problem, I try to render 14 millions of whitewater particles and a 3.5 millions of points polysoup mesh with PBR, mantra gives me the same error, I run under Linux gcc 4.4, 48 gb ram. I try to increase the unified cache to 0.75 of my system memory, without look, both with KD-tree and bounding volume hierarchy. The only thing that seems to work is to increase the raytracing bias to 0.1, but the shadows become almost missed, Is there a better solution to this? Thanks Edited April 17, 2013 by Pazuzu Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted October 23, 2013 Share Posted October 23, 2013 Well I had this same problem yesterday. Taking Geo time samples back to 1 seemed to have fixed it. (I was using a value of 2) It might well be something else in you case. Quote Link to comment Share on other sites More sharing options...
hallogero@gmail.com Posted June 17, 2020 Share Posted June 17, 2020 Hi, I am having the same error in 18.0.499. Any other options what might help. Thanks! Quote Link to comment Share on other sites More sharing options...
hallogero@gmail.com Posted June 17, 2020 Share Posted June 17, 2020 I solved this problem by removing / renaming my Houdini 'Home' folder and running Houdini as Administrator. Quote Link to comment Share on other sites More sharing options...
velozetetic Posted October 17, 2020 Share Posted October 17, 2020 Mantra Error Command Exit Code: -1073741819 I blocked the (# GAMES DEVELOPMENT TOOLSET) in houdini.env the error disappeared. Quote Link to comment Share on other sites More sharing options...
