mightcouldb1 Posted February 15, 2010 Share Posted February 15, 2010 Brickmaps in Mantra. Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 15, 2010 Share Posted February 15, 2010 (edited) .... Erasing comment ... in finding my answer 2 seconds later Edited February 15, 2010 by LaidlawFX Quote Link to comment Share on other sites More sharing options...
Richey Posted February 15, 2010 Share Posted February 15, 2010 - Quick Smoothing Preview Polygons (like in Autodesk Maya via 1,2 and 3) Quote Link to comment Share on other sites More sharing options...
lisux Posted February 15, 2010 Share Posted February 15, 2010 - Quick Smoothing Preview Polygons (like in Autodesk Maya via 1,2 and 3) I think that only applies to NURBS in Maya. Quote Link to comment Share on other sites More sharing options...
kgoossens Posted February 15, 2010 Share Posted February 15, 2010 (edited) I think that only applies to NURBS in Maya. No since 2008 or version 2009 it also applies to polygons. It basically is the same previewing method they have as lightwave has already for a very long time. Edited February 15, 2010 by kgoossens Quote Link to comment Share on other sites More sharing options...
Macha Posted March 8, 2010 Share Posted March 8, 2010 (edited) Being able to navigate the Details View like some of the other views: middle mouse and pan/zoom. Edited March 8, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
Ratman Posted March 8, 2010 Share Posted March 8, 2010 Already submited this as an RFE, but here it is. Better behaviour when working with Primitive Groups, when you select a bunch of them and say you press delete, have them actually be deleted by the primitive group, and not the point numbers, which Is a bad way to be deleting things when using primitive groups. Quote Link to comment Share on other sites More sharing options...
lisux Posted March 8, 2010 Share Posted March 8, 2010 Already submited this as an RFE, but here it is. Better behaviour when working with Primitive Groups, when you select a bunch of them and say you press delete, have them actually be deleted by the primitive group, and not the point numbers, which Is a bad way to be deleting things when using primitive groups. I second that one, I think it have been discussed before but will be really useful. Quote Link to comment Share on other sites More sharing options...
Macha Posted March 9, 2010 Share Posted March 9, 2010 Another two things to speed up work: -A colored preview of the attributetransfersop, similar to what we have in the paintsop, or a simple radius guide in the viewport. -An option in the attributecreatesop to visualize them. At the moment we have to do that manually in the display options and it becomes very tedious especially when you change names. Perhaps they could be added automatically so the visualization could be accessed from both display options and nodes or, like in ICE, simply by middle clicking the node connections. Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted March 17, 2010 Share Posted March 17, 2010 In mplay allowing you to slide and reorganize the order of the images around by clicking on the number, for better organization and comparisons of a whole slew of images. Quote Link to comment Share on other sites More sharing options...
brianburke Posted March 18, 2010 Share Posted March 18, 2010 Improved PBR performance and Features!! Dots in the network view (a-la nuke). Ptex in Mantra and SOPs. Also, that little animation of colorful sperm that comes up when you run a local process should be in stereo. Keep rocking it SESI!! Quote Link to comment Share on other sites More sharing options...
Macha Posted March 18, 2010 Share Posted March 18, 2010 Dots in the network view (a-la nuke). I don't know nuke, but isn't that already there? (display options in network view) Quote Link to comment Share on other sites More sharing options...
glomm Posted March 18, 2010 Share Posted March 18, 2010 Dots in the network view (a-la nuke). i use nulls for that purpose Quote Link to comment Share on other sites More sharing options...
sandzuro Posted March 18, 2010 Share Posted March 18, 2010 Speed, speed, speed. Add GPU acceleration for interactive rendering like in Octane or Arion. GPU acceleration for fluids. Fix a viewport speed. Quote Link to comment Share on other sites More sharing options...
Richey Posted April 12, 2010 Share Posted April 12, 2010 By the way, is there any information about the release date of version 11 (Or will sideFX release a next 10.x before the release of 11?)? Houdini rocks! Have a nice day! Quote Link to comment Share on other sites More sharing options...
barad_dur Posted April 14, 2010 Share Posted April 14, 2010 Create a "Compute" node. Basically I am suggesting that a scene, through a nodal distribution network, can be cooked/recooked faster if that scene has strategically placed nodes that tell all the nodes above it to cook using "This Remote Computing Core or Cores". I would think that the parameters section would have a place to enter the DNS or IP address of the machine you want it to use for cooking that part of the scene. There would also need to be the ability to add additional DNS and IP lines in case the primary machine crashes or is down for some reason.It may just as well have a range ability like "129.188.234.+". It would also have to be able to be disabled so that you can send your .hip to someone else who does not have access to those DNS/IP adresses. One should be built to speak to CPU type cores and one should be built for GPU type cores. Or just bulid one node with a selection menu for GPU or CPU. I have attached a picture if you guys feel so inclined. Comp.bmp Have a great day. David Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted May 4, 2010 Share Posted May 4, 2010 Left, bottom, back viewport views as addition to standard Left, Top, Right. Just like MODO has. Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted May 4, 2010 Share Posted May 4, 2010 And Speed. Quote Link to comment Share on other sites More sharing options...
mawi Posted May 4, 2010 Share Posted May 4, 2010 Abillity to pick and lay down several nodes at once from the tab-menu. Sometimes I`m laying out 5 or more DOP-Gas nodes. It would be so much faster to just type gas once and then ctrl+click all nodes i need. Other then that... Speed. Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted May 4, 2010 Share Posted May 4, 2010 Add a rotating shutter assembly to the lights like an etc source 4 light, and not just the simple barn doors in maya. Quote Link to comment Share on other sites More sharing options...
