bhaveshpandey Posted September 7, 2009 Share Posted September 7, 2009 (edited) I tried installing HOT but am pretty much clueless about it.. could anyone please shed more light on this? I tried looking for it but cant find much around..even on OdWiki and the googlecode from where I downloaded it.. I'm as of now pretty naive with scripting and stuff (I hope this will change soon enough ) so cant really get my head around the whole compiling thingie.. I'm running WinXP, 32 bit, H10.0.374 cheers Edited September 7, 2009 by bhaveshpandey Quote Link to comment Share on other sites More sharing options...
eloop Posted September 7, 2009 Share Posted September 7, 2009 On 9/7/2009 at 9:35 AM, bhaveshpandey said: I tried installing HOT but am pretty much clueless about it.. could anyone please shed more light on this? I tried looking for it but cant find much around..even on OdWiki and the googlecode from where I downloaded it.. I'm as of now pretty naive with scripting and stuff (I hope this will change soon enough ) so cant really get my head around the whole compiling thingie.. I'm running WinXP, 32 bit, H10.0.374 cheers Go to http://code.google.com/p/houdini-ocean-toolkit/ and start by clicking on HOT Documentation. See the bit about installing from a binary distribution. Then load some of the example files. -Drew Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted September 7, 2009 Author Share Posted September 7, 2009 (edited) thanks a ton Drew!! Will give it a whirl and get back (is it compatible with just Visual Studio 2005 or others too??) also it says to install Houdini in C:\apps\Houdini... and then install the Visual studio to C:\apps\VS8 Is it a prerequisite? or its just that VS needs to be in same directory? (or something else) For eg. if I have Houdini installed on D:/Houdini should I install Visual Studio to something like D:\apps\VS8 or not? thanks again.. Edited September 7, 2009 by bhaveshpandey Quote Link to comment Share on other sites More sharing options...
eloop Posted September 7, 2009 Share Posted September 7, 2009 You can only use Visual Studio 2005. You can install the apps anywhere you want as long as you modify the environment variables accordingly. BTW you don't have to do any of this if you just install the binary package. -Drew On 9/7/2009 at 11:58 AM, bhaveshpandey said: thanks a ton Drew!! Will give it a whirl and get back (is it compatible with just Visual Studio 2005 or others too??) also it says to install Houdini in C:\apps\Houdini... and then install the Visual studio to C:\apps\VS8 Is it a prerequisite? or its just that VS needs to be in same directory? (or something else) For eg. if I have Houdini installed on D:/Houdini should I install Visual Studio to something like D:\apps\VS8 or not? thanks again.. Quote Link to comment Share on other sites More sharing options...
abvfx Posted September 8, 2009 Share Posted September 8, 2009 (edited) On 9/7/2009 at 9:00 PM, eloop said: BTW you don't have to do any of this if you just install the binary package. -Drew Im having a few problems aswell. I tried on linux. Didnt have much luck. I built it, but when i had to put in cd .. python setup.py bdist Nothing happens. Maybe its my setup. But it would be really cool if i knew where the binaries are being held. I can only find H10 binaries and im on 9.5. It would be awesome if i could get the binaries pack for HOT_src_1.0rc5.tar.gz (thats the latest on HOT for 9.5 right)? Thanks, I understand if you or anyone doesn't have the time, when i built the linux one unsuccessfully it did take a while. Edited September 8, 2009 by phrenzy84 Quote Link to comment Share on other sites More sharing options...
eloop Posted September 8, 2009 Share Posted September 8, 2009 Can you post the output of the build commands. What linux are you using ? Can you compile SOP_Star.C with hcustom ? The more info you provide the more likely we can debug things. I'm not planning on releasing binaries for linux or old Houdini releases, too many linux's and not enough spare time I'm afraid. But let's get it built from src. -Drew On 9/8/2009 at 8:34 PM, phrenzy84 said: Im having a few problems aswell. I tried on linux. Didnt have much luck. I built it, but when i had to put in cd .. python setup.py bdist Nothing happens. Maybe its my setup. But it would be really cool if i knew where the binaries are being held. I can only find H10 binaries and im on 9.5. It would be awesome if i could get the binaries pack for HOT_src_1.0rc5.tar.gz (thats the latest on HOT for 9.5 right)? Thanks, I understand if you or anyone doesn't have the time, when i built the linux one unsuccessfully it did take a while. Quote Link to comment Share on other sites More sharing options...
abvfx Posted September 11, 2009 Share Posted September 11, 2009 yeah. Thing is its probably my system. Im getting a new comp next month so i will try again then, and if i dont get any further i will post my results and take it from there. Just wanted to get off the ground. But thanks for offering your help, you have created an awesome toolkit (form what i can tell ) and im sure i will be up in no time. thanks again, -Andrew Quote Link to comment Share on other sites More sharing options...
jacys Posted September 22, 2009 Share Posted September 22, 2009 (edited) I followed the website's step to build HOT. But I have this error message when I start houdini. I have set the environment variables as the website'd mentioned. But I notice this error msg is from that environment var. How come? Edited September 22, 2009 by jacys Quote Link to comment Share on other sites More sharing options...
eloop Posted September 22, 2009 Share Posted September 22, 2009 What version of houdini are you using ? -Drew On 9/22/2009 at 5:01 PM, jacys said: I followed the website's step to build HOT. But I have this error message when I start houdini. I have set the environment variables as the website'd mentioned. But I notice this error msg is from that environment var. How come? http://images.plurk.com/4676003_b85b063d41cd7616b90b05d415c78071.jpg Quote Link to comment Share on other sites More sharing options...
jacys Posted September 23, 2009 Share Posted September 23, 2009 On 9/22/2009 at 9:27 PM, eloop said: What version of houdini are you using ? -Drew I just downloaded HOT for Houdini 10.401 yesterday, and my version is 10.401, too. Quote Link to comment Share on other sites More sharing options...
jacys Posted September 23, 2009 Share Posted September 23, 2009 (edited) btw, I could compile the hcustom Star.C... That's so wierd why I could not compile the HOT. I compiled this in my studio(WIN32). My home computer's OS is WIN64. I try these teo way to compile HOT but all failed. However, when I compile Star.C, it works. problem_record.txtFetching info... Edited September 23, 2009 by jacys Quote Link to comment Share on other sites More sharing options...
eloop Posted September 23, 2009 Share Posted September 23, 2009 I just worked out that I had a dumb bug in the script that I use to build the hotbin_****.zip files. Please download the latest src/binary and give it another go. Sorry for the inconvenience. I'm very interested to hear peoples experiences, so please tell me if this fixed things for you. BTW this was stuffing up the OSX binary release as well. -Drew On 9/23/2009 at 5:45 AM, jacys said: btw, I could compile the hcustom Star.C... That's so wierd why I could not compile the HOT. I compiled this in my studio(WIN32). My home computer's OS is WIN64. I try these teo way to compile HOT but all failed. However, when I compile Star.C, it works. Quote Link to comment Share on other sites More sharing options...
jacys Posted September 23, 2009 Share Posted September 23, 2009 Hi Drew, I just use your new script to compile HOT in win32 and win64 platform a few minutes ago. Unfortunately, they all were failed. It still could compile the hcustom SOP_Star.C in these different platforms. But when I compile the "hython setup.py bdist", it jumps the error window which I posted yesterday again. There is a bit distance to reach the goal soon, just need make it clear more. Really dont know where is the problem. Hopeless. Thanks to your hard work. Quote Link to comment Share on other sites More sharing options...
jacys Posted September 23, 2009 Share Posted September 23, 2009 Is there someone who compile success in windows? no matter win32 or win64. Can you tell me your compile HOT way step by step? Quote Link to comment Share on other sites More sharing options...
jacys Posted September 23, 2009 Share Posted September 23, 2009 hold on, I make it. Tonight I'll have a party to celebrate it. Wooooohaaaaaaaaa.... happy!!!! Quote Link to comment Share on other sites More sharing options...
eloop Posted September 23, 2009 Share Posted September 23, 2009 Hi Jacys, What did you have to do to get it compiling ? Was there something wrong in the documentation ? -Drew On 9/23/2009 at 3:26 PM, jacys said: hold on, I make it. Tonight I'll have a party to celebrate it. Wooooohaaaaaaaaa.... happy!!!! Quote Link to comment Share on other sites More sharing options...
jacys Posted September 24, 2009 Share Posted September 24, 2009 (edited) On 9/23/2009 at 6:33 PM, eloop said: Hi Jacys, What did you have to do to get it compiling ? Was there something wrong in the documentation ? -Drew Sure, I noticed there were some *.dll files in the dso folder before I compile it. I check another computer that never compile HOT, soon I notice they were wrong files where wrong place. I deleted them, then I deleted the Env Var that I set before. Here is a point, because I set HOUDINI_PATH and PATH in user Env Var, that's totally wrong perhaps. However, it works in System Env Var. If not, I dont know why, but I just adjusted them to system Env Var, and it works. Never jump any error window ever. It might be a mistake here, I just share my experience and try to figure the right way out. After I re-set Env Var, I compiled it again. There is nothing appear in the wrong place anymore. Thanks to Drew's hard work. I start to expect the Win32 version. I will use VEX for some advanced application test tonight. Edited September 24, 2009 by jacys Quote Link to comment Share on other sites More sharing options...
oohoo Posted October 30, 2009 Share Posted October 30, 2009 I got this error message below. ERROR: Couldn't open resource file "resources" (No such file or directory) Can't open dophints.cmd ERROR: Couldn't open "Fuse10.0.430/FUSE_ColorOptions.ui" for reading: No such file or directory I set ENV VAR in SYS ENV like the documentation mentioned. BTY, I use WinXp 64bit. Any one can help? Thanks!!! Quote Link to comment Share on other sites More sharing options...
edward Posted November 2, 2009 Share Posted November 2, 2009 My guess is that you forgot the ;& part at the end of your HOUDINI_PATH. Quote Link to comment Share on other sites More sharing options...
eloop Posted November 2, 2009 Share Posted November 2, 2009 I'll second that guess. On 11/2/2009 at 1:54 AM, edward said: My guess is that you forgot the ;& part at the end of your HOUDINI_PATH. Quote Link to comment Share on other sites More sharing options...
