Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
art3mis
[Redshift] accessing CHOP network from inside RS vopnet
Hi
I want to use a standard chop expression ie “chop(obj/chop_network/OUT/myValue)” inside a RS vopnet to animate a shader value.
Is this possible?
What RS node should I be using?
Share this post
Link to post
Just make a parameter for the value, and link the parameter to the chop outside the shader itself.
Share this post
Link to post
Thanks. Total novice when it comes to manipulating shader VOPs. How would I animate brightness or saturation values when the standard Redshift material has no input for those parameters?
Share this post
Link to post
Yep, that is the limit of the Redshift Volume, it accepts no inputs at this time.
However, you can supply two fields to control the look. Use your CHOP value to modulate the field in question. Brightness would typically be associated with heat or temperature but you can create any custom field.
Just think of it as a standard Houdini pyro task. How would you route brightness from CHOPs into pyro in general?
Once you have that solved and you can see the result in the viewport, write out a .bgeo.sc sequence from the DOP I/O node and assign a Redshift Volume as the material.
Another option would be to add a rsMaterial and connect it to the surface input. The rsMaterial does have an emission component which can accept input from an attribute. Write your CHOP value to a point attribute (scatter into a volume) then fetch the attribute in the VOP network using a rsPointAttribute node. Redshift gets a little slow on export using this technique but you should experience ok render times with points counts up to several thousand.
For an example on routing point attributes to rsMaterial check out the Redshift procedural planet example file I posted in the thread you started for Redshift examples.
Edited by Atom
Share this post
Link to post
Thanks Atom! Where I am stumbling is my understanding of
Quote
" Write your CHOP value to a point attribute (scatter into a volume)"
In the attached image you can see I have defined a new point attribute at the Obj level, and then inside at SOP level used the following VEXpression to reference the CHOP data. ` backquotes seemed to be necessary
`v@point = chop("/obj/music/LOW_OUT/low")*10`
And then in my RS vopnet created a ParticleAttributeLookup piped to emission_color of a RS_Material which in turn is piped to the Surface parameter (picture 3)
Am I on the right track?
Edited by art3mis
Share this post
Link to post
Here are a couple of ways.
You can directly modulate the Source Volume Scale using a CHOP expression.
That same expression can drive the Emission weight in the vopnet too. So you can skip the step of converting CHOP to an attribute and routing it through the Redshift attribute system.
ap_rs_CHOP_To_Modulate_EMIT.hiplc
ap_rs_CHOP_To_Modulate_Source_Volume.hiplc
Edited by Atom
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
