"Pyroclastic noise" demystified
Hazoc
Many (me included) have been wondering what is this pyroclastic noise all the big boys are talking about since google knows very little about this. The following paper gave the answer: http://tessendorf.org/papers_files/RIV.pdf
It's basicly just about displacing a surface with a summed set of noise layers on different scales like any fractal texture. The only special thing is that the absolute value of the noise is used and the "valley" areas of the displaced surface/volume are left smooth by scaling down the displacement power of the noise layers with previous layers.
Here's an extremely simple VOP SOP setup demonstrating the basic idea.
pyroclastic_noise.hip
  • Like 2
Hey Hazoc
Thanks for sharing. As far as I know the smoothing in the valleys is a recent addition for clouds. Traditional pyroclastic doesn't even have that :). But yeah, that volumetrics paper is an amazing resource.
And this is going to be a must have when it's released: http://magnuswrenninge.com/visualeffects/book-in-the-works
M
Hey Hazoc
Aah, I see:) My hip file does pretty ugly job at valley smoothing but the general idea is very neat and very important element when chasing natural looking cumulus clouds.
That book is intriguing! Must buy.
hi, the ateam clouds look fantastic! the pyroclastic style looks much better then all the noise in volume stuff. but I thought that the volume displacement happens at rendertime. I made a quick example in cvex to demonstrate ( sorry for the hickerystyle, had no coffee, yet). even so it is on soplevel it should be easy to translate to shop and get extradetail in rendering through the volumesamples,
pyroclastic_cvex.hip
but displacing spheres is easy, the real cool stuff happens with the bunny again. can somebody explain how this levelset stuff works, or how to implement that in houdini? Creating displacment on displaced geometry is straight forward, but doing this on volumes, huh??
Yes it does but as I've just started learning volume displacement shading, I could not provide a proper example:) Nice file, thanks!
What comes to maintaining the right displacement direction or "normal" when operating with bunny -type geometry, their "Felt" language explained in the paper allows handy looping. I believe you can only determine normal directions to iso surface from a SDF gradient field which you in this case rebuild after each noise layer addition and use as a guide for the next layer of noise.
would be cool if this would happen at renderstage
Nicely done!
I'm still trying to understand some parts conserning the iterative layering process and levelset described in the paper.
(page 19)
"The crucial property here is that the each fractal layer represents a range of spatial scales that is higher frequency that the previous layers. Conversely, an early layer has relatively
large scale features. This implies that sampling the levelset into a grid that has
sucient resolution to capture the spatial features of one layer still allows sub-
sequent layers to apply higher spatial detail displacements."
What ?? Since voxel grid of some resolution is able to store details of some frequency, it is therefore able to store higher frequencies as well ? Can't I just read or what is really being said here ?
@ bunker: cool file, wicked to just look deeper into the volume with displacement. still i think the paper tries to explain a way to layer displacements one after the other wiht that levelsets. in your solution you get the normal to displace by at the beginning but what about adding a displacement on the resulting shape?
Hi guys,
I've been working on this for the last few days and just thought I'd share some results. Any comments are more than welcome.
I've pretty much followed the A-Team paper to the letter. I haven't added the gridless advection to this one but think I've
got a nice way to do that. If I get a chance I'll see if I can post an example with that in to see the difference.
very nice ! :D how are you guys getting the normals for displacement?
geometry ? volume gradient ? or volume converted to geometry ?
@martin : Yes, I should use the normals from a previous displacement.
Edited by bunker
Hi Julien,
I'm actually using a volume gradient.
I'm fairly happy with it but I just can't seem to get the definition in the lower level noises as they are in the paper. Maybe it's just a case of playing with the noise functions a little.
I might try and give it a go with the method you used in your example file.
