Simple batch script iconvert
Should be simple but I don't know much about batch scripting
On Windows, I want to convert a folder with randomly named (some of the sequences, some not) images to rat with the same name but no numbers at the end. For example:
bla_3.hrd
bla_2.hdr
bla_-1.hdr
gthg.hrd
dumdeedum.txt
should become something like
bla_3_t.rat
bla_2_t.rat
bla_-1_t.rat
gthg.rat
How do I go about that?
Edited by Macha
I wrote a little PowerShell script for this, take a look. Open it in any text editor, and edit first 3 variables. :rolleyes:
The only thing you need to do is to figure it out, how to run PowerShell scripts :) There is a permission issue.
It's easy to fix... link
convertRAT.rar
Edited by Stalkerx777
For such purposes I use simple Shelf Tool with python code like this:
from os import listdir,path,system,environ
root = environ["HIP"]+"/textures"
root = "d:/imgs"
for file in listdir(root):
    file = path.join(root,file)
    system("iconvert "+file+" "+file[:-3]+"rat")
It's easy to modify the root folder with images or expression for filenames.
Here is my shelf script for batch-converting images from within Houdini:
import hou
import os
iconvert = hou.houdiniPath()[3] + '/' + "iconvert.exe"
folder = hou.ui.selectFile(title='Images Folder')
files = os.listdir(folder)
dot = "."
extension = "rat"
exts = ('.exr', '.jpg', '.tga', '.png','.tif', '.hdr')
def rat_folder():
    for file in files:
        file_ext = file[-4:]
        if file_ext in exts:
            export = iconvert + ' ' + '"' + folder + file + '"' + ' ' + '"' + folder + file[:-4] + dot + extension + '"'
            exists = os.path.exists(folder + file[:-4] + dot + extension)
            if exists is True:
                status = "File exists. Skipping..."
            else:
                os.system(export)
                status = "Success!"
            print "----------------------------------------------"
            print "RAT FOLDER STATUS: " + status
            print "original=" + folder + file
            print "new=" + folder + file[:-4] + dot + extension
if folder != '':
    safety = hou.ui.displayMessage("Are you sure you want to convert all images in " + folder + " ?", buttons=('Yes', 'No'))
    if safety == 0 and folder != '':
        rat_folder()
Just paste it into a shelf button. When you press the button, a dialogue will appear that asks for the path. Just select the folder and not any file and press Accept. I have a second button that runs gconvert with extension = "bgeo" for batch object conversions.
  • 3 years later...
import hou
import os
dot = "."
extension = "rat"
def rat_folder():
    for file in files:
            if exists is True:
            else:
                os.system(export)
                status = "Success!"
if folder != '':
        rat_folder()
I've modified your script a little bit to accept files with extensions wich are longer or shorter then three symbols (ex. *.tx or *.tiff)
import hou
import os
dot = "."
extension = "rat"
exts = ('.exr', '.jpg', '.tga', '.png','.tif', '.hdr', '.tx')
def rat_folder():
    for file in files:
        file_ext = os.path.splitext(file)[1]
            export = iconvert + ' ' + '"' + folder + file + '"' + ' ' + '"' + folder + os.path.splitext(file)[0] + dot + extension + '"'
            exists = os.path.exists(folder + os.path.splitext(file)[0] + dot + extension)
            if exists is True:
            else:
                os.system(export)
                status = "Success!"
if folder != '':
        rat_folder()
  • 9 months later...
I was trying to get this work on linux, but failed miserably, what should be changed if need to run on linux?
Please help.
Thanks
  • 1 year later...
I changed the script to work on Linux. THANKS to Ole You only need to change the Path to your Houdini Linux Install(iconvert = "/opt/hfs16.0.600/bin/iconvert-bin")
import hou
import os
#the script converts all files in the same directory like your file selection
file = hou.ui.selectFile(title="Image Selection")
folder = os.path.dirname(file)+"/"
dot = "."
extension = "rat"
def rat_folder():
    for file in files:
            if exists is True:
            else:
                os.system(export)
                status = "Success!"
if folder != '':
        rat_folder()
Update: i managed to make it running (hopefully) on all Operating systems not just Linux. Thanks to Symek and Legomyrstan
import hou
import os, sys
iconvert = hou.expandString("$HFS"+"/bin/"+"iconvert")
#iconvert = "/opt/hfs16.0.600/bin/iconvert-bin"
dot = "."
extension = "rat"
def rat_folder():
    for file in files:
            if exists is True:
            else:
                os.system(export)
                status = "Success!"
if folder != '':
        rat_folder()
  • 2 years later...
Many thanks for sharing your code. None of the above versions works on Win 10, Houdini 17.5.258.
I have coded the snippet below that (hopefully) solves several version  & OS related problems.
I checked it on Windows only and works.
Hope you can find it useful, give me some feedback if you encounter problems.
import hou, os
iconvert = hou.getenv("HFS")  + "/bin/" +"iconvert.exe"
iconvert = os.path.abspath(iconvert)
folder = hou.ui.selectFile(title='Images Folder', file_type=hou.fileType.Directory)
folder = hou.expandString(folder)
dot = "."
extension = "rat"
def rat_folder():
    for file in files:
        realName = os.path.abspath( folder + file)
        file_ext = realName[-4:]
            export = iconvert + " " +  realName + " " + realName[:-4] + dot + extension
            exists = os.path.exists(realName[:-4] + dot + extension)
            if exists is True:
            else:
                os.system(export)
                status = "Success!"
            print "original = " + realName
            print "new ="  + realName[:-4] + dot + extension
if folder != '':
        rat_folder()
Kind regards,
Ippokratis
  • Thanks 1
