Bump and true displacement at the same time
Hello
I remember that I found the way how to achieve true displacement + some tiny bump noise. Now I can't recall how I have done this.
I want to have true displacement + some noise bump at the same time and in one shader. Do i have something to add or mix? Hope you can help, it's ultra newbie question, sorry.
I think you might misunderstood me.
I am making new material and I want to have bump over displacement.
I am geting "displace along normal" node which do true displacement. Another displace along normal node is doing bump displacement [only shading, not true displacement]. Now, I want to mix them, but I don't know how.
I dived into mantra surface but I can;t clearly see how it is solved there.
