vtwinracersp2 Posted December 16, 2012 Share Posted December 16, 2012 i've been using fedora 17. it's a pain because of the frequent updates which make things break. simple things are just broken. i would just like to have a stable OS. i always feel like the rug is being pulled from underneath me. i was thinking about switching to centos or rh. centos is basically rh without the branding and support (with centos receiving updates a little later)? my main concern is the nvidia driver. currently centos uses an older version (290) of the nvidia driver? how is it updating the latest nvidia drivers and how well do they work? do they work as well with the older kernel that centos uses? how stable is houdini with centos? Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted December 16, 2012 Share Posted December 16, 2012 Houdini is very stable in Centos 6.2. Installing latest binary blob drivers from nvidias homepage is no problem. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted December 17, 2012 Share Posted December 17, 2012 Fedora can be stable and reliable enough but it depends on how you set things up. For example if you install graphics drivers directly from Nvidia (or AMD) every time the kernel is updated they will break. If you install the graphics drivers from RPM Fusion they will compile a new kernel module when the kernel gets updated. Having said that I'm not a fan of Fedora because of the extremely short release life cycle and temporary nature. Fedora is basically the beta of RHEL. If given the choice I'd use Ubuntu 12.04 LTS which will be supported until April of 2017 and has things like graphics drivers in the official repositories. CentOS is a good option in theory because CentOS 5 and 6 will be supported for a decade but their track record has been hit and miss (in particular punctuality). Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted December 17, 2012 Share Posted December 17, 2012 Wanted to chip in that I would also use Ubuntu or maybe Mint if I did not not have to run any Autodesk products. Quote Link to comment Share on other sites More sharing options...
Neil78 Posted December 20, 2012 Share Posted December 20, 2012 Yep - i use Mint Maya 13 and houdini runs perfectly. Erik - does Maya not install too well in Mint? Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted December 20, 2012 Share Posted December 20, 2012 Yep - i use Mint Maya 13 and houdini runs perfectly. Erik - does Maya not install too well in Mint? Since Mint is based on Ubuntu (which is based on Debian) it uses Debian packages (DEB) instead of Redhat Packages (RPM). Maya can be installed but you have to jump through some hoops to do it. Worth noting that Autodesk won't support Maya on Debian or any Debian based Linux distribution so if you run into trouble you're on your own. Quote Link to comment Share on other sites More sharing options...
Neil78 Posted January 2, 2013 Share Posted January 2, 2013 Ah I see - thanks for that Luke - I didn't know that. By the way - your Linux tutorials on CMIVFX were really excellent - and set me on the Linux road - many thanks for that. Luckily - i don't need Maya right now........ Quote Link to comment Share on other sites More sharing options...
moondeer Posted April 9, 2013 Share Posted April 9, 2013 luke's linux lesson at cmivfx is the only one i know of directed specifically at a VFX. it is a good one. Quote Link to comment Share on other sites More sharing options...
amination Posted April 9, 2013 Share Posted April 9, 2013 luke's linux lesson at cmivfx is the only one i know of directed specifically at a VFX. it is a good one. Luke Olson himself is the author of those lessons in CMI I'm just going ahead and agree with Luke here, I've been using Ubuntu Studio for few years now and it has been doing fantastic job on Houdini, specially with its graphic drivers. Quote Link to comment Share on other sites More sharing options...
art3mis Posted October 1, 2016 Share Posted October 1, 2016 So Ubuntu is the preferred choice? Quote Link to comment Share on other sites More sharing options...
