Follyx Posted April 16, 2013 Share Posted April 16, 2013 Hi, if Iuse a filecache SOP, start rendering, I get following: /obj/bldg_front/filecache1/rop_geometry1: Awaiting 1 queued writes.. any suggestions (sure ;-) Thanks in advance Quote Link to comment Share on other sites More sharing options...
Skybar Posted April 16, 2013 Share Posted April 16, 2013 To my understanding, it means that everything is essentially complete - it is just waiting for that last file to be written to disk. Quote Link to comment Share on other sites More sharing options...
Follyx Posted April 16, 2013 Author Share Posted April 16, 2013 unfortunately not Peon, anyway thanks ;-) Quote Link to comment Share on other sites More sharing options...
kleer001 Posted April 16, 2013 Share Posted April 16, 2013 Personally I don't like the FileCache SOP (yet). I still use the ROP Output Driver SOP and an accompanying File SOP. Quote Link to comment Share on other sites More sharing options...
anim Posted April 19, 2013 Share Posted April 19, 2013 Personally I don't like the FileCache SOP (yet). I still use the ROP Output Driver SOP and an accompanying File SOP. so does the FileCache SOP if you look inside the problem here is not the message, but most probably that you didn't set the Valid Frame Range parameter on FileCache to Render Frame Range the default Render Any Frame will still allow you to set frame range (should be disabled) but it will cache only current frame Quote Link to comment Share on other sites More sharing options...
