robert.magee Posted July 19, 2013 Share Posted July 19, 2013 We have just released a new Production Build Houdini 12.5.469. Normally I wouldn't announce this outside our forums this but this version has an important new feature. The Alt key can now used to invoke View tools. Now there will be no more muscle memory issues for Maya artists learning Houdini. The spacebar can also be used so Houdini artists don't have to change existing habits. The new keystroke is on by default but there is a preference for turning this off altogether if you don't want it. Houdini 12.5.469 is available for download - http://www.sidefx.com/download or http://www.sidefx.com/apprentice Quote Link to comment Share on other sites More sharing options...
sambuev Posted July 19, 2013 Share Posted July 19, 2013 How can I switch options from "spacebar" to "Alt", Now you've set "Alt" as "Esc" Quote Link to comment Share on other sites More sharing options...
Magnus Pettersson Posted July 21, 2013 Share Posted July 21, 2013 For me ALT+RMB is still controlling FOV instead of zoom in and out like with SPACE Quote Link to comment Share on other sites More sharing options...
Sifis Posted July 21, 2013 Share Posted July 21, 2013 I don't understand. Everything works the same as before. The alt key still doesn't invoke any viewtools. Quote Link to comment Share on other sites More sharing options...
sanostol Posted July 21, 2013 Share Posted July 21, 2013 You have to turn it on in the preferences preferences>3d Viewports I don't understand. Everything works the same as before. The alt key still doesn't invoke any viewtools. Quote Link to comment Share on other sites More sharing options...
malexander Posted July 21, 2013 Share Posted July 21, 2013 The Alt-view perference is now the default, but this pref has been around for a few dozen builds now and it defaulted to off. So it's likely that it has been saved to $HOME/houdini12.5 as 'off'. This is why you have to explicitly turn it on if you've had a previous 12.5 version installed (unless you wipe out your prefs by deleting $HOME/houdini12.5, which isn't recommended). 1 Quote Link to comment Share on other sites More sharing options...
Magnus Pettersson Posted July 21, 2013 Share Posted July 21, 2013 (edited) For me it works as before if i turn it off (as it should), but when turning it on and holding ALT and pressing: LMB is rotating, MMB is panning, Scrolling its zooming but RMB it is changing "Screen Window Size" (not FOV like i wrote before) like when it is turned off, not zooming in/out like when holding space. I guess correct behavior should be exactly the same as space Is it only me that gets this result? tested on win8 64bit Build 469 Edited July 21, 2013 by Magnus Pettersson Quote Link to comment Share on other sites More sharing options...
Guest tar Posted July 21, 2013 Share Posted July 21, 2013 works as expected on os x. Alt+LMB rotates, MMB pans, RMB fov Quote Link to comment Share on other sites More sharing options...
Magnus Pettersson Posted July 21, 2013 Share Posted July 21, 2013 works as expected on os x. Alt+LMB rotates, MMB pans, RMB fov When you say work as expected, is Alt+RMB moving the camera position (as with space) or actually changing the fov? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted July 21, 2013 Share Posted July 21, 2013 true - it does change the fov instead of dollies Quote Link to comment Share on other sites More sharing options...
robert.magee Posted July 23, 2013 Author Share Posted July 23, 2013 true - it does change the fov instead of dollies It actually looks like it changes the Screen size window parameter which is like zooming into the camera view as if it was a flat 2D image. None of the camera's 3D parameters or focal length are changed. Both should Dolly. Thanks for pointing this out. It will be looked at right away. Quote Link to comment Share on other sites More sharing options...
grayOlorin Posted August 15, 2013 Share Posted August 15, 2013 Hey Robert, any update on the status of addressing the Dolly/Zoom issue? Sorry, excited about rolling this out Quote Link to comment Share on other sites More sharing options...
grayOlorin Posted August 16, 2013 Share Posted August 16, 2013 this is all working in 12.5.496! thank you SESI! Quote Link to comment Share on other sites More sharing options...
Magnus Pettersson Posted August 16, 2013 Share Posted August 16, 2013 Nice! byebye accidently "space destroying" expressions Quote Link to comment Share on other sites More sharing options...
