resolve takes into main
Hi there, I've used takes to help setup a simulation. Now that I have the sim the way I want, I would like to just get rid of all the extra takes, but resolve the take parameters for a particular take into the main scene take. Does that make any sense?
I know I can just copy over the parameters manually, but there's gotta be a quicker way, and without missing a parameter.
I don't see a way to do this in the take manager, unless im missing something ;)
Thanks!
  • 3 years later...
Hi, I must be missing something very simple in the syntax:
Trying to merge take1 to main.
/ -> takemerge main take1
Unable to find destination take main
After that, I figured it must be the capitalization of Main..
/ -> takemerge Main take1
Couldn't merge source take take1
But still not working..
I tried looking for examples from other take commands that requires a <take> as an argument.. closest I got was for takename.
/ -> takename take1 take1b
That one works.
As a semi-workaround. I created a new take under Main, and renamed it "master".
/ -> takemerge master take1
Now the takemerge works.. but only for sibling takes.
Is it possible to merge a take to Main using takemerge?
On 8/6/2013 at 2:21 AM, substep said:
hmmm, this doesnt seem to work for merging things into the "Main" take.
edit: nm, it seems the destination take must be the active take when merging.
Were you able to merge it to the Main? If so, what syntax did you use? :)
  • 5 months later...
I got a python code working (so far). This collects the parameters set by the takes, then transfers those to the Main take.
Simply set to a take you want to resolve to main, then run the code.
mTake = hou.takes.rootTake()
cTake = hou.takes.currentTake()
if mTake.name == cTake.name:
    hou.ui.displayMessage('Please set to a Take other than the \'Main\' take.')
else:
    tParms = cTake.parmTuples()
    nodes, parms, value = [], [], []
    for p in tParms:
        nodes.append(p.node())
        parms.append(p.name())
        value.append(p.eval())
    hou.takes.setCurrentTake(mTake)
    for i in range(len(nodes)):
        nodes[i].parm(parms[i]).set(value[i][0])
Current limitation is that this will not include parent takes. I'll try and add recursion on my next free time.
  • 1 year later...
Hi Galagast, thanks for your take merge snippet. Unfortunately I had some issues with it, but I could fix it:
main_take = hou.takes.rootTake()
current_take = hou.takes.currentTake()
if main_take.name == current_take.name:
else:
    parameter_tuples = current_take.parmTuples()
    parameter_value_dict = {}
    for parameter_tuple in parameter_tuples:
            for parameter in  parameter_tuple:
                parameter_value_dict[parameter.path()] = parameter.eval()
    hou.takes.setCurrentTake(main_take)
    for key, value in parameter_value_dict.items():
        print 'setting current parameter %s == %s' % ( key, value)
        hou.parm( key ).set( value )
    print 'merged %s Take into Main' % current_take.name()
I was also to lazy to make it recursive, so it doesn't takes care of parent takes.
  • 1 year later...
After some time has passed I figured out that Houdini offers a very handy solution to merge a take in to the main take. It's the addParmTuplesFromTake function:
else:
    hou.takes.setCurrentTake( main_take )
    main_take.addParmTuplesFromTake(current_take)
The only thing that I couldn't figure out was a solution to also merge the display, render and bypass flags into the main take.
  • 1 year later...
Here a script that takes also display-,render- and bypass-flags into account:
def getAllFlagStates():
    flags_dict = {}
    for node in hou.node('/').allSubChildren():
        flags_dict[ node.path() ] = {}
        flags_dict[ node.path() ]['Display'] = node.isGenericFlagSet(hou.nodeFlag.Display)
        flags_dict[ node.path() ]['Render'] = node.isGenericFlagSet(hou.nodeFlag.Render)
        flags_dict[ node.path() ]['Bypass'] = node.isGenericFlagSet(hou.nodeFlag.Bypass)
    return flags_dict
else:
    flags_dict = getAllFlagStates()
    for node_path in flags_dict:
        node = hou.node( node_path )
        if node.isGenericFlagSet( hou.nodeFlag.Display ) != flags_dict[ node_path ]['Display']:
            node.setGenericFlag( hou.nodeFlag.Display, flags_dict[ node_path ]['Display'] )
        if node.isGenericFlagSet( hou.nodeFlag.Render ) != flags_dict[ node_path ]['Render']:
            node.setGenericFlag( hou.nodeFlag.Render, flags_dict[ node_path ]['Render'] )
        if node.isGenericFlagSet( hou.nodeFlag.Bypass ) != flags_dict[ node_path ]['Bypass']:
            node.setGenericFlag( hou.nodeFlag.Bypass, flags_dict[ node_path ]['Bypass'] )
