wateryfield Posted March 6, 2014 Share Posted March 6, 2014 Hi, everyone. I have a fog volume with pyro materia have to render, the defaut render looks not good enough, so i have to modify the materia by turn on the displacement . But the pyro displacement need the Normal field, how can i get the normal? I just transfer the polygon normal to the fog volume simeply, it works,but looks not properly. I get some tip in forum,but i can not set it to work. Anyone who give a help will be great. Thanks. get_normal.hip Quote Link to comment Share on other sites More sharing options...
Skybar Posted March 6, 2014 Share Posted March 6, 2014 You can't get normals in your volume that way. You want a field for that, specifically a vector field, which points in the right direction. With an SDF that is easy because it is negative inside and positive outside (or the other way around, i never remember). So you want to get the gradient of your density field, a gradient points to increasing values. Because it is an SDF then it will act as a normal for your volume. Here is a hip for that, and since I cant remember how an SDF works you can disable/enable the Volume Mix SOP to invert the normal field. You then of course specify it in your shader to use for displacement. get_normal_dv.hipnc 2 Quote Link to comment Share on other sites More sharing options...
