NodeZArt - art with nodes
zeee
hey guys,
here's some fun art work that ive made in the node editor of houdini. Yes, in the node editor. No photoshop.
Im calling it NodeZArt.. cuz its simply art with nodes.. icon_smile.gif and it has my initials too (ZA)..
Lemme know wat you think...
post-4317-0-17593700-1406794454_thumb.jppost-4317-0-06375300-1406794397_thumb.jppost-4317-0-86020500-1406794287_thumb.jp
post-4317-0-52371100-1406794481_thumb.jppost-4317-0-44943200-1406794494_thumb.jppost-4317-0-97147500-1406794508_thumb.jp
nice one... :-)
there should be somewhere a script that arranges nodes per image file but i couldn't find it...
EDIT:
Found it....
http://forums.odforce.net/topic/839-fun-with-nodes/
There es even something on vimeo:
https://vimeo.com/87243405
https://vimeo.com/87346518
Edited by Mandrake0
Sweet! How manual was this process?
  On 7/31/2014 at 8:18 AM, zeee said:
hey guys,
Well its pretty much procedural. Took an image into houdini, converted it to point data so that i can set the resolution of tiling within houdini itself and then a python script to read that data n display as nodes.
So its just Houdini , some Python and a dash of ingenuity! :)
  On 8/6/2014 at 6:54 PM, zeee said:
Ha! Classic! :)
Oh one comment I forgot to mention in the other thread. Are you turning off undos when you do this? It might speed up creation time a bit. Check out the python example here:
http://www.sidefx.com/docs/houdini13.0/hom/hou/UndosDisabler
  On 8/7/2014 at 2:09 AM, edward said:
Ha! Classic! :)
Interesting.. I'll have a look at that..
What i figured out is that changing the color of an existing node is faster than creating a new node. So i check if the current node (point) was present in previous frame, if yes then change color of existing node else put a new node. And in the end of the loop i check if any node were present in previous but not in current then delete the nodes. This sped up the process quite a lot.
One again, thanks for the interesting tip !
