The node name and font content
1. I wonder why the node name can't be digital-only, such as 1, 2 or 10.1.
2. And another problem, i want create a font with content was the number of the node name, such as the node name was s11 , the font content was 11, how can i get the number,  opdigits(`$OS`) not working at font.
3. I can get the name by $OS in Hscript, how to get the node name use VEX, and where can i find all the VEX attributes?
Any help will be appreciated.
Thanks!
1. probably the same reason why variable in any programming language can't be a number, how would you distinguish between variable and number?
2. as you are putting expressions into string field, you need to use ticks
`opdigits($OS)`
3. you can create string parameter and put $OS in there
or in wrangle snippets you can insert `$OS` into your code like
string name = `$OS`;
or in shading context you can use getobjectname() finction
not sure what you mean by all VEX attributes, here are some links:
http://www.sidefx.com/docs/houdini13.0/vex/contexts/
http://www.sidefx.com/docs/houdini13.0/vex/snippets
http://www.sidefx.com/docs/houdini13.0/vex/functions/
  • Sad 1
`opdigits($OS)`
Anim, Thanks for your super fast respond.
There is too much thing i have to learn.
I will have a try soon!
`opdigits($OS)`
Anim, I get a problem.
Is  `$OS` can direct insert into wrangle .
s@s = name;
or
s@s = `$OS`;
It not working, or i was a wrong syntax.
And the getobjectname() finction   , I confuse with the
  1. string getobjectname()
Returns the name of the current object whose shader is being run, or the empty string if there is no current object.
 What mean whose shader is being run?
Thanks!
Edited by wateryfield
s@s = name;
I don't think there is a VEX function that will let you grab the node name but an easy workaround is to edit the parameter interface (via the gear button) and add a string parameter to your node.
Let's call it operator_name
In the new created field you can type $OS to access the name you want.
It is now accessible in your VEX code via the ch() function.
s@my_name = ch("operator_name");
EDIT : after anim answer (below), I learnt that you can actually easily access '$' variable with simple double quotes... thanks :)
Edited by iamyog
s@s = name;
or
s@s = `$OS`;
my mistake, I was writing from top of my head instead of checking in H
this is the correct syntax
string name = "$OS";
the $OS gets expanded and inserted into VEX code before that get's compiled.
it wouldn't work with animated variables as VEX is compiled only on first frame, but $OS is not changing so it should be safe
Thanks!
it means it returns the name of the object that the shader belongs to/is called from
so if you have 2 objects A and B and you assign the same shader to them with getobjectname() function inside
that function returns A when evaluating that shader on object A and B when evaluating it on B etc.
Thanks, it is a good idea.
And anim 's answer working well too.
Thanks.
Working!
