How to make VDB smooth? (VDB from polygon)
I tink subdivide wont work cause there no vertices and no points  in a VDB object. Wont work.
You can do a VDB smooth and convert it back to polygons. In any case you loose the origin topo.
If the VDB is not urgently neccessary for your network process, try another way.
I'm not sure (please anyone correct me if I'm wrong):
As VDB's are a mathematic model of your origin geo (similiar to NURBS), the edges will be interpreted as (tadaa) edges ;-). So between 2 Polys i.e. on a sphere.the edge have to be the highest area. I think there is no way to smooth it out with a technique similiar to smoothing groups in max cause its "just" a equalization of different light bouncing points, wheras your problem is based upon "real" geometry. Try to lower the voxel size in your "vdb from poly" to i.e 0.005 and you will see the edges very sharp. As smaller the voxels wich "bathe" the geo, as sharper are not coplanar objects; here edges.
If you just want to stop the overload of points in your object, try to work with packed primitives.
What do you want to achieve?
Edited by Follyx
I mean to subdivide before converting to vdb.
As VDB's are a mathematic model of your origin geo (similiar to splines), the edges will be interpreted as (tadaa) edges ;-). So between 2 Polys i.e. on a sphere.the edge have to be the highest area. I think there is no way to smooth it out with a technique similiar to smoothing groups in max cause its "just" a equalization of different light bouncing points, wheras your problem is based upon "real" geometry. Try to lower the voxel size in your "vdb from poly" to i.e 0.005 and you will see the edges very sharp. As smaller the voxels wich "bathe" the geo, as sharper are not coplanar objects; here edges.
If you just want to stop the overhaul of points in your object, try to work with packed primitives.
Yes you are right. Subdiv is the best way for now.
Looks like you've hit the Nyquist limit. i.e. you're sampling the polygon geometry at a frequency higher than the details of the geometry itself. This oversampling means you won't get smooth interpolation across the SDF, because you're matching the source geometry too closely. Try increasing the voxel size.
Yes for high detail it convert like what you said I thought.
I use VDB from polygon to convert my geometry to VDB, but the VDB is very sharp and seems losing smooth group, like we use unique point in Facet, how can I get a smooth VDB?
My geometry:
VDB:
The polygon sphere looks smooth because it has smoothed normals but smoothed normals don't translate into more polygons or smoother geometry. The geometry you see showing through on the VDB is exactly the geometry of the polygon. If you want the VDB to appear smooth then give it smoother geometry to start with (subdivided, higher frequency, etc.).
Thanks!
