Juraj Posted September 29, 2015 Share Posted September 29, 2015 (edited) Hello, I've come across this awesome video and paper. So I decided to try to implement it into Houdini as it seems very efficient way to do RBDs. I think that I almost have it, but I am encountering strange problem with Transform Pieces node. I have managed to "upres" it once but when I use the same workflow to add another layer it behaves very strange. Please could you have a look on my file and check it? (also if you notice something inefficient in my implementation please suggest better solution ) Thanks, Juraj project.hipncFetching info... Edited September 29, 2015 by Juraj Tomori 4 Quote Link to comment Share on other sites More sharing options...
coolcoke33 Posted September 29, 2015 Share Posted September 29, 2015 I recently just done the similar RnD for this. So for transform pieces node, u need to have the same name attribute from the low rez sim to track the animation. Quote Link to comment Share on other sites More sharing options...
anim Posted September 29, 2015 Share Posted September 29, 2015 (edited) you forgot to post the link to your RnD http://forums.odforce.net/topic/20957-houdini-rbd-rnd-deforming-tearing/ Edited September 29, 2015 by anim Quote Link to comment Share on other sites More sharing options...
coolcoke33 Posted September 29, 2015 Share Posted September 29, 2015 Thank you Tomas! Actually I have new one I just figure out how to fix track animation from low rez, so I updated Quote Link to comment Share on other sites More sharing options...
Juraj Posted September 29, 2015 Author Share Posted September 29, 2015 Hi, thank you for your replies. But I still have problems with this Transform pieces node. In first stage of "upres" it works like expected. However if I use the same setup to add another "upres" it doesn't do its job correctly. The name attribute is correct and there is same amount of pieces and points. Any clues? Quote Link to comment Share on other sites More sharing options...
coolcoke33 Posted September 29, 2015 Share Posted September 29, 2015 Hi, I'm sorry I was misunderstanding ur question. So I find if the points in rbd sim is using deform data that the point's v, w and orient would be 0, so I think that makes Transform pieces node not working properly. I will try to have 2 separate group with active and deform one, then active group transform pieces with new sim's point data, deform one with old one. Quote Link to comment Share on other sites More sharing options...
Juraj Posted September 30, 2015 Author Share Posted September 30, 2015 Hi, I tried your advice but I still can't get it working. I am really stuck here. Could anybody check my hip and suggest a solution? project.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
coolcoke33 Posted September 30, 2015 Share Posted September 30, 2015 I think the problem now is the geometry to transform needs the position of geo when the rbd turn active = 1 instead of frame 1. Cause the point data calculate starts when it turns active. Quote Link to comment Share on other sites More sharing options...
Juraj Posted October 2, 2015 Author Share Posted October 2, 2015 Hi, thanks, now it works better but there is still slight offset (please check attached hip file). I think that it has something to do with rest positions. But in this setup I have no idea what should they be. Any suggestion? project.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Juraj Posted October 9, 2015 Author Share Posted October 9, 2015 Hi, I have been trying to get my head around Transform Pieces workflow. So I tried to manualy generate orient attribute and then use it to drive Transform Pieces. It matches original closely but there is slight offset. Solid geometry is transformed and templated is original. Any ideas what is causing that? example_scene_forum_align.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Juraj Posted October 9, 2015 Author Share Posted October 9, 2015 After looking around odforce I found Anim's great solution to this. Now it works like a charm example_scene_forum_align_better.hipncUnavailable 3 Quote Link to comment Share on other sites More sharing options...
Juraj Posted October 14, 2015 Author Share Posted October 14, 2015 So I managed to finish it Thanks for support, I learned a lot. 2 Quote Link to comment Share on other sites More sharing options...
f1480187 Posted October 15, 2015 Share Posted October 15, 2015 (edited) And I learned a lot too by repeating other people work. Thanks for the smart solution of dealing with impacts. Used it in a homebrew impact analysis SOP. I experienced slight offseting of dop-imported geometry too. "Solve On Creation Frame" checkbox on RBD Packed Object DOP fixed this problem, but I have no idea what causing it. Maybe certain intrinsic attributes on packed fragments combined with side effects of secondary simulation. I've downloaded your scene, but you managed your simulation in a different manner and this option was already turned on, not fixing anything. column.hipncFetching info... Edited October 15, 2015 by f1480187 2 Quote Link to comment Share on other sites More sharing options...
Juraj Posted October 15, 2015 Author Share Posted October 15, 2015 Hi, nice result In my final version I didn't use DOP's data to track new fragments. I computed transformation matrix myself - that seemed to be most flexible solution. Quote Link to comment Share on other sites More sharing options...
sparkChan Posted March 24, 2016 Share Posted March 24, 2016 On 10/14/2015 at 12:52 AM, Juraj Tomori said: So I managed to finish it Thanks for support, I learned a lot. hi, have you ever tried to add some glue constraints to the bullet sim. I did, but the glue constraints didnt work. Quote Link to comment Share on other sites More sharing options...
Juraj Posted March 24, 2016 Author Share Posted March 24, 2016 Hi, I didn't try it, but it should be possible. Quote Link to comment Share on other sites More sharing options...
