meldrew Posted March 10, 2016 Share Posted March 10, 2016 Hi all, I've been trying to figure out how to create a linear ripple effect (i.e. rather than have a single point as the source, I'd like to source it from a line/selected edge/group of points, so that it travels across a surface like a wave.) Now, of course, at a basic level the 'waveform' SOP node performs this exact operation - *However* it can only generate a single wave at a time, and it lacks the signature 'decay' of the ripple over time. I had the idea of using the wave operation in CHOPS using a sine wave with decay on it, however any changes to the amplitude are applied across the whole waveform, rather than 'at birth'. So it doesn't create a dying wave, it just scales down the whole waveform. (see image). Any ideas on how to achieve this? (just as an FYI, eventually I'd like to control the decay length with an animatable paramater & creation/scale of the ripple from CHOPS with a trigger.) It seems like it should be super easy - Maybe I'm just having a bit of a mental block! :/ Any mind jogging greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Juraj Posted March 11, 2016 Share Posted March 11, 2016 Hi, check ripple solver, it might help you Juraj Quote Link to comment Share on other sites More sharing options...
meldrew Posted March 11, 2016 Author Share Posted March 11, 2016 Hi Juraj, Thanks - Of course I have looked at the ripple tools, but I can't find a way to give any ripple a 'linear' source, it will always source from a single point coordinate. For example, I'd like to select all the points along 1 edge of a grid, and have them all be the source. Do you know of any way to accomplish this? As I mentioned, the waveform SOP is essentially the form I want, however it doesn't have the decay functionality. Thanks! Quote Link to comment Share on other sites More sharing options...
Juraj Posted March 14, 2016 Share Posted March 14, 2016 Hi, I created setup where you can use curve as source for ripples. Check example file. Juraj jt_ripple.hipnc 1 Quote Link to comment Share on other sites More sharing options...
meldrew Posted March 16, 2016 Author Share Posted March 16, 2016 Hi Juraj, Thanks for the scene file - It explained your suggestion perfectly! I think it would be nicer to do this in VOPS or SOPS, however I am now getting a nice effect (which isn't too slow) with the DOPs setup. Thanks again for the help! (As you can probably tell, I am the definition of 'Peon'! ha) Quote Link to comment Share on other sites More sharing options...
mestela Posted March 16, 2016 Share Posted March 16, 2016 Here's a procedural way, might give you some ideas. float speed = @Time * ch('speed'); float frequency = ch('frequency'); @P.y = @Cd.r*sin(@Cd.r*frequency+speed)*ch('height'); @Cd = 1; ripple_wrangle.hipnc 6 Quote Link to comment Share on other sites More sharing options...
meldrew Posted March 17, 2016 Author Share Posted March 17, 2016 Oh cool, thanks Matt! Ok, so as far as I understand from your file/wrange: You define 'speed' as global time multiplied by a variable that you just define within that same wrangle. And then edit parameter interface to make a slider for it? Didn't realise you could do that - My hscript/VEX knowledge is pretty non existent. (Just as some context: My bg is in fine art, I just picked up Houdini for the first time about 6 months ago & am only just getting into it fully. Awesome tool!) Thanks again for taking the time to make that example - Really appreciate it! Quote Link to comment Share on other sites More sharing options...
mestela Posted March 17, 2016 Share Posted March 17, 2016 Yep. More info here: http://www.tokeru.com/cgwiki/index.php?title=HoudiniVex 1 Quote Link to comment Share on other sites More sharing options...
H2O Posted March 22, 2016 Share Posted March 22, 2016 Thanks Matt! Really helpfull indeed! Cheers, Quote Link to comment Share on other sites More sharing options...
6ril Posted December 6, 2016 Share Posted December 6, 2016 thanks Matt ! Just what I was trying to achieve ! And in such a simple/clever way ... and real time! Much much appreciated. Quote Link to comment Share on other sites More sharing options...
