sessionbeer Posted May 6, 2016 Share Posted May 6, 2016 Hello, Could any one please help me with getting this helix to follow the input curve? I have a vop that generates a helix from the input curve which is great, I just need to make it follow the input curve as a guide now which is where I'm stuck. Appreciate any help offered, Thanks Helix_AlongCurve_01.hip Quote Link to comment Share on other sites More sharing options...
SreckoM Posted May 6, 2016 Share Posted May 6, 2016 (edited) May I suggest different approach. helix_curve.hipncFetching info... Edited May 6, 2016 by SreckoM 1 Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted May 6, 2016 Author Share Posted May 6, 2016 Thanks for your suggestion SreckoM, Unfortunately the reason why I didn't go down that route (by using a sweep sop), was because I need to apply this system to a lot of multiple curves at once, the sweep sop will simply be to much of an over head to keep the scene usable. This is why I tried to keep it to vop's or vex to get the speed gains. Quote Link to comment Share on other sites More sharing options...
yesyes Posted May 6, 2016 Share Posted May 6, 2016 wire capture wire deform etc Quote Link to comment Share on other sites More sharing options...
Popular Post f1480187 Posted May 6, 2016 Popular Post Share Posted May 6, 2016 // Point wrangle. #define PI 3.1415926535897932384 float u = fit01(@u, -PI, PI) * ch("revolutions"); vector pos = set(sin(u), cos(u), 0) * ch("radius"); matrix3 t = set(v@tangentu, v@N, v@tangentv); @P += pos * t; Where tangents and normal was computed by PolyFrame SOP, and @u is 0..1 point's position on curve. spiralize.hipnc 17 Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted May 6, 2016 Author Share Posted May 6, 2016 Thanks f1480187, This looks like a really good solution! And something to learn from. Thank you Quote Link to comment Share on other sites More sharing options...
michael Posted May 6, 2016 Share Posted May 6, 2016 On 5/6/2016 at 12:35 PM, f1480187 said: // Point wrangle. #define PI 3.1415926535897932384 float u = fit01(@u, -PI, PI) * ch("revolutions"); vector pos = set(sin(u), cos(u), 0) * ch("radius"); matrix3 t = set(v@tangentu, v@N, v@tangentv); @P += pos * t; Where tangents and normal was computed by PolyFrame SOP, and @u is 0..1 point's position on curve. Expand Edit > Aliases and Variables > Variables ....PI 4 Quote Link to comment Share on other sites More sharing options...
varomix Posted November 4, 2016 Share Posted November 4, 2016 On 5/6/2016 at 12:35 PM, f1480187 said: // Point wrangle. #define PI 3.1415926535897932384 float u = fit01(@u, -PI, PI) * ch("revolutions"); vector pos = set(sin(u), cos(u), 0) * ch("radius"); matrix3 t = set(v@tangentu, v@N, v@tangentv); @P += pos * t; Where tangents and normal was computed by PolyFrame SOP, and @u is 0..1 point's position on curve. spiralize.hipncFetching info... Expand Thank you this is amazing 1 Quote Link to comment Share on other sites More sharing options...
haputka Posted November 6, 2016 Share Posted November 6, 2016 Hi! Please take a look at an asset I've made some time ago exastly for the same purpose. You can use pscale attribute on input curve to control spiral radius alongway (see attached scene file). Best regards goryu_Simple_Spiral.hda spiral_along_curve.hipnc Quote Link to comment Share on other sites More sharing options...
varomix Posted November 7, 2016 Share Posted November 7, 2016 On 11/6/2016 at 7:30 AM, haputka said: Hi! Please take a look at an asset I've made some time ago exastly for the same purpose. You can use pscale attribute on input curve to control spiral radius alongway (see attached scene file). Best regards goryu_Simple_Spiral.hdaFetching info... spiral_along_curve.hipncFetching info... Expand Thank you I will check it out, I ended up doing something similar with the example given above, added a ramp to control the radius along the curve as well thanks again Quote Link to comment Share on other sites More sharing options...
lazza79 Posted June 5, 2017 Share Posted June 5, 2017 Hi Guys, these are excellent examples, but if I try to do the spiral for a curve with direction 0,1,0 the spiral is not happening... I am sure it has something to do with the trigonometry of the thing but I don't know how to solve it... Any idea? Cheers! Andrea spiralize_vertical.hipnc Quote Link to comment Share on other sites More sharing options...
adrianr Posted June 6, 2017 Share Posted June 6, 2017 On 6/5/2017 at 1:39 PM, lazza79 said: Hi Guys, these are excellent examples, but if I try to do the spiral for a curve with direction 0,1,0 the spiral is not happening... I am sure it has something to do with the trigonometry of the thing but I don't know how to solve it... Any idea? Cheers! Andrea spiralize_vertical.hipncFetching info... Expand The Polyframe isn't calculating any vectors from the line. You can make a cheap N on the line like {1,0,0} and it will work. I've also attached a method using Entagmas sweep sop framing trick. You can switch between the 2 at the bottom to see how the different framing changes how the curve wraps (Do this on the curve, not on the line, no point there really). You can see how it holds up better especially at the top of the curve. This method works for the line without an incoming N too. Be sure to switch on the scene visualizers for point normal, tangentu and tangentv so you can see the differences in the vectors themselves, rather than just the end result. spiralize_sweep.hipnc Quote Link to comment Share on other sites More sharing options...
