merging several curves into one ?
Hello,
Is there a way to merge several curves into one, I mean consider several segments as one, without physically connecting them (like the join sop is doing).
I am quite stuck on this.
Many thanx
Thx, I just don't need them to connect, just being considered as one multi segment curve with coherent point number.
Let's say you just merge two curves together (each one with 10 points) , the result is 2 primitives with one general point numbering from 0 to 19, which is nice, but the carve SOP is dealing with the 2 primitives and cutting them as two separated objects. I would like the carve to act like it was dealing with one curve with gaps, jumping from one segment to another.
Sorry if I am not clear, thanx a lot for your answers.
Wow, thx for the wiki paper, very interesting.
Thanx a lot f1480187, very clever, couldn't think it would so complex, I will study it carefully.
In cinema 4d there is a generator called Mospline that gets this option is someone in interessed.
I couldn't take a look at the posted scenefiles, but you could try to group all existing points/edges, connect curve ends by proximity, use carve for animation and then delete the connecting edges.
  • 4 months later...
