city shapes to rectangles
rodstar
Hi
I need some help from the guys with the big brains :D.
I have some complex Shapes from osm data inside houdini.
So i want create some buildings out of this shapes .But the complexity
of this polygons complicate the procedural modeling a lot.
So it would be so much easier , if i have just rectangles or kind of rectangular
Shape. So have someone an Idea how to achieve this ?
It dont have to be total accurate.
Read a lot about packing and packing Problem , but have to say that these Papers with 30 Pages of formulas
are over my head.
Please help :(
well for a quick/dirty result try:
  • a divide node set to remove unshared edges
  • Hole that result
  • facet that with remove inline points enabled
  • divide that result with "avoid small angles" enabled
That probably gives you something slightly better to start from (if you haven't already)
After that there are multiple options, but none of them are super straightforward (hence the 30 page papers :P)
Personally I would probably go with some Attribute wrangle to find the corners that I want to use and then dissolve all the edges that are less useful,
then divide again and maybe repeat those steps a couple of times.
Tbh, I am also not super sure what I would do, but it does look like an interesting challenge :P
Edited by acey195
Sorry for the late reply.
Here is a an example File from my Scene.
I converted the osm Files to a Obj with osm2World because i cant find a better script/tool to get all the stuff from a osm file(<relation v=multipolygon).
@acey195 this is excatly what i tried, but didnt get a accectable Result.
"convex decomposition" sounds great.:blink: I will read some stuff
cityShape.hip
I still found no proper solution, so if someone has fun with this stuff ,  i would be so happy.
Very cool @petz!
just for fun, I tried a SOP solver approach, very brute force but good for packaging squares :D
just a "fill" method on one square at a time, if it's not square of filled enough, move to another area ...
converting the points to a shape needs a lot of work...
city3.pngI
using the osm map with a bit of cleanup of the edges and some random extrusion...
bunker_city.zip
Edited by bunker
added 3d view
  • Like 2
One of the expected problems may occur due to VOP SOP implementation of early Point Wrangle. Some variables use different names. Another one is that VEX library was about two times smaller. For example getpointbbox function was added in H14. But getbbox must be and do similar job there. It returns different results for non-polygonal geometry, where surface are not fully bound with points.
Edited by f1480187
