squardis Posted July 4, 2016 Share Posted July 4, 2016 Hi, i suddenly hitted a button witch now have everything smoothed out in the viewport. Its like maya 3 button or max turbo smooth. How can I change this back? thnx Quote Link to comment Share on other sites More sharing options...
fencer Posted July 4, 2016 Share Posted July 4, 2016 check this parameter 2 1 Quote Link to comment Share on other sites More sharing options...
malexander Posted July 5, 2016 Share Posted July 5, 2016 You probably pressed `+` to turn on subdivision. You can do when fencer suggests above or press `-` to turn it off. 2 Quote Link to comment Share on other sites More sharing options...
squardis Posted July 7, 2016 Author Share Posted July 7, 2016 BOTH THNX!!! that helped Quote Link to comment Share on other sites More sharing options...
McNistor Posted May 15, 2019 Share Posted May 15, 2019 @malexander Hi Mark, Is there a way to display an obj as sub-d but hide the hull? Quote Link to comment Share on other sites More sharing options...
malexander Posted May 15, 2019 Share Posted May 15, 2019 Yes, switch to Shaded (instead of Wire over Shaded). 1 Quote Link to comment Share on other sites More sharing options...
jamesearnest244 Posted November 20, 2020 Share Posted November 20, 2020 Has this hotkey been changed since Houdini 16? The + and - don't seem to do anything in Houdini 18. I've read about this having been changed to Shift +/-, but that doesn't work either. Quote Link to comment Share on other sites More sharing options...
malexander Posted November 20, 2020 Share Posted November 20, 2020 The hotkey is still Shift - and Shift =. You need to have at least one object selected for it to do anything, as it changes the objects' "Display As" parameter. It also does not do anything within a LOP-contained SOPnet, as there is no object parameter to change. Quote Link to comment Share on other sites More sharing options...
Kuchavo Posted March 2, 2021 Share Posted March 2, 2021 Quote Link to comment Share on other sites More sharing options...
