Distance on Mesh
Igor
if your mesh doesn´t have holes in it and you need just the distance betwen two points, it´s fairly easy to calculate. take a look at the attached file. it basically uses the fact that a real geodesic path unfolds into a straight line in the plane. so, all you have to do is to unfold the curve comming from the shortestPathSop and measure the euclidian distance between both endpoints...
hth.
petz
geodesic_distance.hipnc
  • Like 5
18 minutes ago, Zybrand said:
Great example Petz thanks. What is the outerproduct function and matrix multiplication for it the first wrangle node? It does not seem to change any of the attributes when I remove it.
it doe´s project the vector onto the plane defined by the point normal. it´s there to make sure that the points of the 1-ring are correctly sorted even on distorted meshes. to see the difference, visualize the local frame (vec_u and vec_v) as attributes.
hth.
petz
I still don't see a difference in vec_v with or without the * mat so does that mean vec_v is already on the plane defined by the normal? But I can see the difference it makes further down where you are calculating sort_val so I can see the results but I don't fully understand it :). What is the matrix you get from outerpoduct of a vector and itself? Is it the normal direction in matrix form and subtracting that from the ident() gives you the plane you want to project the vector too?
thanks,
Zybrand
thanks,
Zybrand
take a look at the file
project_vec.hipnc
  • Like 2
  • 1 year later...
  • 4 years later...
