Linux newbie Nvidia drivers & related questions
art3mis
not sure if there is something wrong with my install
finally have redshift licensing working, now H Indie won't launch!
All I see is a splash screen then nothing!
Does this indicate I should start from scratch, or is there an easier solution?
deleted my config files, didn't help.
Guessing a driver issue...again
also wondering, are other flavors of linux equally sensitive to driver related issues?
Perhaps switch to Ubuntu, Fedora, or even downgrade to Centos 6 from 7?
same issue?
https://www.sidefx.com/forum/topic/27201/
crash report
Crash report from root; Houdini Version 15.5.673 [linux-x86_64-gcc4.8]
Uptime 0 seconds
Mon Dec  5 22:54:01 2016
Caught signal 11
Traceback from 4074 ThreadId=0x7f6ac3426240
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
_L_unlock_13 <libpthread.so.0>
QReadWriteLock::lockForWrite() <libQtCore.so.4>
QGLWidget::deleteTexture(unsigned int) <libQtOpenGL.so.4>
QGLContext::~QGLContext() <libQtOpenGL.so.4>
QGLWidget::~QGLWidget() <libQtOpenGL.so.4>
re_QGLWidget::~re_QGLWidget() <libHoudiniUI.so>
QObjectPrivate::deleteChildren() <libQtCore.so.4>
QWidget::~QWidget() <libQtGui.so.4>
re_QWindowWidget::~re_QWindowWidget() <libHoudiniUI.so>
RE_QtWindow::~RE_QtWindow() <libHoudiniUI.so>
UI_Window::~UI_Window() <libHoudiniUI.so>
QT_Window::~QT_Window() <libHoudiniUI.so>
FUSE_AnonymousStats::~FUSE_AnonymousStats() <libHoudiniAPPS3.so>
FUSE_App::~FUSE_App() <libHoudiniAPPS3.so>
FUSE_HoudiniBinariesApp::~FUSE_HoudiniBinariesApp() <libHoudiniAPPS3.so>
__run_exit_handlers <libc.so.6>
__GI_exit <libc.so.6>
UT_Exit::doExit(int, bool) <libHoudiniUT.so>
RE_OGLRender::initGLState() <libHoudiniUI.so>
RE_OGLRender::makeCurrent(bool) <libHoudiniUI.so>
RE_OGLRender::lockContextForRender() <libHoudiniUI.so>
RE_QtWindow::openWindow(int, int) <libHoudiniUI.so>
QT_Window::doOpen() <libHoudiniUI.so>
UI_Window::handleEvent(UI_Event*) <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::drainEvents(bool, bool) <libHoudiniUI.so>
OPUI_MainApp::loadFilesAfterUiOpen(UI_Event*) <libHoudiniAPPS2.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main <libHoudiniUI.so>
__libc_start_main <libc.so.6>
OPUI_MainApp::precreateApplication(int&, char const**) <hindie-bin>
Edited by art3mis
