Cloth to Alembic - UV Missing
Hey guys, I really need some help here,
I'm in the middle of a project and can't export the simulated cloth with proper UVs (exporting it as alembic / must work in Maya)
Here are some statements about the situation:
- if I export the grid mesh, with no simulation, the UVs are read correctly outside of Houdini;
- if I export the simulation, directly from the dopimport1 node, it doesn't work outside of Houdini;
- the UVs are ok when I import it back to Houdini (and unpack the geometry);
- the cloth is gettin' ripped on my original scene, this way I can't use an attribute copy to get the uvs from the original mesh (since it's point count is changing);
- If I import it to 3ds Max, it work's at the first frame but as soon as I run the timeline it get id of the uv. I can get the 1st frame uv to stick to the object if I add an Unwrap UVW modifier to it. Tried to export it from Max to Maya but it doesn't work;
I did a quick test here in a much simplier scene, with a plane only and get the same problem.  The scene file is attached + 2 exported alembics (with and without simulation)
Thank's in advance ;)
Cloth Problem.rar
Edited by ParticleSkull
trying to make everything clearer ;)
