Juzwa Posted February 15, 2017 Share Posted February 15, 2017 Hi, So Im having problems caching substeps of my animation. I have substeps on File Cache node set to 16, and the path is "$HIP/../cache/$OS/$OS.$F4.bgeo". Maybe the $F4 is the issue? Maybe I should change this to be able to save not only the frames but the substeps as well? Quote Link to comment Share on other sites More sharing options...
younglegend Posted February 15, 2017 Share Posted February 15, 2017 Try caching the animation with ROP output node and instead of $F4 try $N. Quote Link to comment Share on other sites More sharing options...
Juzwa Posted February 15, 2017 Author Share Posted February 15, 2017 (edited) With sop output driver (increment = 1/substeps) I get the same, stepping animation. $N cache a single frame Edited February 15, 2017 by Juzwa Quote Link to comment Share on other sites More sharing options...
Juzwa Posted February 15, 2017 Author Share Posted February 15, 2017 (edited) Or maybe its not the caching issue? Maybe the read only loads on full frames? But File node does not have any settings for substeps.... Edited February 15, 2017 by Juzwa Quote Link to comment Share on other sites More sharing options...
younglegend Posted February 15, 2017 Share Posted February 15, 2017 Oh ya, forgot to mention. You can't read the cache back in as sub steps. There has been discussions about it. None worked for me. What i usually do is Cache out using sop output with increment 0.1 and $N. That way sub steps are saved as integer frame numbers; then i read it back in and play it with 0.1 step in the viewport. 1 Quote Link to comment Share on other sites More sharing options...
Juzwa Posted February 15, 2017 Author Share Posted February 15, 2017 (edited) Hm... I cant get it to work your way. Especially that $N does not work well with strings. Eg "../$OS/$OS.$N.bgeo" evaluates to "../Cache/Cache..bgeo". So a single frame is beeing overwritten But that really suchs you cannnot load on substeps. Thats just silly that you have the option to save with substeps, but you cannot load it? EDIT. Ok got it. So I just use "../$OS/$N.bgeo" on rop output. And indeed when I change the increment to sth different than 10 is overwrites just single frame. But workes with 10. Weird workoround but looks like it does its job Edited February 15, 2017 by Juzwa Quote Link to comment Share on other sites More sharing options...
fencer Posted February 15, 2017 Share Posted February 15, 2017 Maybe this direction. sub_cache.hipnc Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted February 15, 2017 Share Posted February 15, 2017 In the past I've used Time Shift > ROP then back in with File > Time Shift. Multiply and divide things by whatever with the Time Shift and it doesn't matter what the frame numbers are on the ROP and files. If you're doing DOP stuff it saves out the substep by default. Quote Link to comment Share on other sites More sharing options...
