Voronoi Fracture Issues
3dome
Hi guys,
so I got this house model which I'm going to destroy. When it comes to voronoi fracturing (create inside surfaces turned on) I get strange chunks coming out of the walls.
I don't really know where it comes from (I guess it's the triangulation inside voronoi fracture) and I don't know how to fix it.
I tried converting the mesh into VDB and fracture that but even there are some chunks sticking out.
I attached the file.
Cheers
housefracture_to_odforce.hip
Here is an approach I often take when fracturing. I will use a divide in Bricker mode to add some grid like faces to the entire object. I use an isooffset to convert the shape into a volume. I increase resolution so the volume closely represents the shape. This allows the scatter points to exist inside the volume and not just on the surface of the faces. I use a low count scatter into the volume and follow that up with a point replicate whose count I set to 10, down from the default of 100. Then I lower the scale on the point replicate. This gives you small clusters of points scattered around. I feed that into the voronoi fracture and it produces less uniform final pieces.
NOTE: I did not see any "strange chunks" in your original file. Do these appear during simulation?
Edited by Atom
thanks Atom that's quite a nice way.
unfortunately I still get odd chunks. I wonder why you did not see them in my file.
even with your method I get them...
Edited by 3dome
in voronoifracture4, untick Create Inside Surface
(and voronoifracture2 ?....Dunno...it's cooking cooking cooking.....dunno what it's doing...)
...finally.....I think voronoifracture2 needs it ON
Edited by Noobini
i actually need inside surfaces. and the fracture 2 was just a test with VDBs.
anyway i fixed it. had to add quite a lot of polysplits on the inside of the walls so they have proper 4 sided polygons.
