Ber Posted April 28, 2017 Share Posted April 28, 2017 Hi everyone, I'm currently working on a blast/pyro effect, and I need some advices about fast colliders. I've fast moving collider that doesn't affect correctly my pyro. the solver seems to be unable to correctly evaluate the motion of my object. Any idea about how to solve this problem. I've a simple animated VDB collider (2 fileds vel and collisionvel) Cheers Bertrand Quote Link to comment Share on other sites More sharing options...
derjcmp Posted April 28, 2017 Share Posted April 28, 2017 Normally increasing the substeps should do the trick. Also, make sure on your Sop to Dop bindings, you are using the correct vdb names. Quote Link to comment Share on other sites More sharing options...
Atom Posted April 28, 2017 Share Posted April 28, 2017 (edited) On the Pyro Solver under Advanced TAB, then Collision, you may want to try turning off Correct Collisions. Sometimes this correction is wrong for fast moving objects. Edited May 5, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
Ber Posted May 5, 2017 Author Share Posted May 5, 2017 Many thanks for the answers! Increasing the solver's substeps changes the pyro behavior, and turning off correct collision didn't change anything :/ Thanks Bertrand Quote Link to comment Share on other sites More sharing options...
afx Posted October 4, 2017 Share Posted October 4, 2017 Thanks Atom! The checkbox makes a world of a difference. Quote Link to comment Share on other sites More sharing options...
rodmac Posted October 4, 2017 Share Posted October 4, 2017 If you are saving your volume collisions to disk then you only have integer frames using $F but using $SF will give you the substeps. Sub samples in your second sim probably won't do much otherwise. So export your collision volumes with whatever substeps are required and make to two sims match using volume.$SF.vdb that's my guess anyway. Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted October 4, 2017 Share Posted October 4, 2017 (edited) If you want better collision behavior, you have two options. By default the smoke/pyro solver uses the Multigrid projection method with just one iteration; This method is very fast but not good to deal with collisions, so try to increase the iterations, that can help a little bit. The second option is to change the projection method to PCG, its slower than multigrid, but gives a much better collision behavior! You can find this option on the Advance/Projection tabs in the solver. I hope this helps you! Alejandro Edited October 4, 2017 by Pazuzu Quote Link to comment Share on other sites More sharing options...
afx Posted October 4, 2017 Share Posted October 4, 2017 Thanks Alejandro, increasing the iteration and unchecking the Correct Collisions seemed to give me something more promising. Although I would like to see how your suggestion results in. I'll give that a go today. Thanks many. rodmac, I was under the impression that when substeping, timeblend-ing does the same thing. You just need to do it before converting to a volume? I might be mistaken though. Quote Link to comment Share on other sites More sharing options...
