Delay start of DOP
Trying to delay the start of a simulation until a specific frame is reached.
Using the following Vexpression inside a POP Attract SOP in my AutoDOP network.
Can anyone tell me why it isn't working? ie no delay is happening, the effect starts on frame 1.
Also tried $FF instead of $SF.
if($SF>10){
forcescale = -500;
I have encountered some situations where a sim will not work right if you delay activation. If you go up one level, the entire dopnetwork, itself, has a start frame. If you run into bad behavior try setting the dopnetwork start frame instead.
hmm..just foolin' around again...and realised that you could set this Start Frame to a negative number....
anyway, found another way....Activation = 1, Force Scale = if($SF>10,-500,0) (this way you get 2 values of force)
Edited by Noobini
