caskal Posted July 7, 2017 Share Posted July 7, 2017 Hello magicians, I saw a great image by Lee Griggs the other day and I tried to replicate, here is the original effect He did it with Arnold (i think in maya), by projecting a texture into a volume density, here is some explanation https://support.solidangle.com/pages/viewpage.action?pageId=55710284 I didnt know how to project a texture into density, so I projected a texture, the deleted by color and converted that into vdb > fog, but that way I don't get any depth, any ideas? I've read about a rest field that does something like UV on volumes but cant figure out how Here are my attempts: Hip file attached, Cheers! volnoise3.hip 4 Quote Link to comment Share on other sites More sharing options...
caskal Posted July 9, 2017 Author Share Posted July 9, 2017 @f1480187 @Atom @eetu any of the wizards got a clue on this? Cheers Quote Link to comment Share on other sites More sharing options...
caskal Posted July 9, 2017 Author Share Posted July 9, 2017 Figured out, not sure if this is the best option but seems to work, scattered points and used a point cloud, I'm glad I finally understood the point cloud stuff Hip attached in case someone finds useful Cheers! voldensed.hip 1 Quote Link to comment Share on other sites More sharing options...
ch3 Posted July 11, 2017 Share Posted July 11, 2017 There are many ways you can project onto volume. The rest field is one of them and as you mentioned it can been used as UVs. I tend to skip that step and directly use the P which has been fitted to a the bounding box of the desired projection. It's easier to try that on a volumeVOP to begin with. Let's say you want to project along the Y axis between x and z values of -10 to 10. All you need to do it fit the x and z values within that range so you have a 0 to 1 and feed that to the UVs (st) of the texture node. You can even have a second object as input and automatically get its bounds to calculate your fit range. Now if you want the projection to be on an arbitrary axis, you will have to do some extra maths to rotate the P, project and rotate back within VOPs, or if it's easier, you can do it at the SOP level. What is important to keep in mind, is that volumeVOP will operate on a voxel level and you will never get any sharper detail than the voxel size. But once you do this, you can easily transfer the same nodes/logic onto a volume shader, which operates on rendered samples, which means you can go as sharp as your texture. But of course if you move your camera away from your projection axis, the texture representation will get blurred along that axis. But then again, that's just one approach and maybe there are other ways that may give you more control and better results. 3 Quote Link to comment Share on other sites More sharing options...
caskal Posted July 14, 2017 Author Share Posted July 14, 2017 @ch3 thanks for the info!, about the rest field, how do I add that manually? rest sop has nothing to do with it, right?, I readed that when you do a pyro sim the rest stuff can be added checking a box, but how do I add manually in the sop context, ie: if I create my own vdb? About volume vop, I understand the half of the stuff but will play with Houdini until I get there, thanks again for the direction! Cheers Quote Link to comment Share on other sites More sharing options...
ch3 Posted July 14, 2017 Share Posted July 14, 2017 I may be wrong about the rest volume, but can't you just manually make 3 volumes one for each axis and use a volume wrange to populate the values like that? @restX = @P.x; @restY = @P.y; @restZ = @P.z; I believe this makes sense to use when you advect it together with density, so you can have a reference to a "distorted" coordinate to drive noises with. Otherwise using the above rest fields will be the same with using world space P in the shader (P transformed from screenspace to worldspace) 1 Quote Link to comment Share on other sites More sharing options...
caskal Posted July 16, 2017 Author Share Posted July 16, 2017 On 7/14/2017 at 3:49 PM, ch3 said: I may be wrong about the rest volume, but can't you just manually make 3 volumes one for each axis and use a volume wrange to populate the values like that? @restX = @P.x; @restY = @P.y; @restZ = @P.z; I believe this makes sense to use when you advect it together with density, so you can have a reference to a "distorted" coordinate to drive noises with. Otherwise using the above rest fields will be the same with using world space P in the shader (P transformed from screenspace to worldspace) Expand Thank you! Will give a shot! Quote Link to comment Share on other sites More sharing options...
Popular Post Deviner Posted November 28, 2017 Popular Post Share Posted November 28, 2017 (edited) Hello, here is some of my attempts to do something similar. But I can't get a similar level of detalization in mantra. If somebody can suggest some tips it wound be amazing volume is still a little bit blurry, I guess it could be because of texture resolution vol-0001_volume_v01.hipFetching info... Edited November 28, 2017 by Deviner 9 2 Quote Link to comment Share on other sites More sharing options...
