Hello everyone...  I have a problem with an RBD packed object inheriting velocity.  In the file, I have the attribute active being set by another object, but the velocity doesn't kick in at all.
The velocity works if I remove the point wrangle setting active to 0 and remove the sop solver.
If I try a pop vop or a geo vop, there's some weird velocity behavior that happens.
If I tick on override attribute, the velocity takes off big time and doesn't appear that gravity takes hold.
All I'm looking for is initial velocity once the pieces become active.
I saw a few threads on the side fx forums and this forum, but nothing I saw seems to be working.
Any thoughts?
test_active_velocity.hipnc
Hello Neil,
Unfortunately something changes in the latest houdini versions about the inherit velocity from pack objects, a working way for inject the velocity only at the activation frame it's creating an attribute containing the previous @active value ($F-1), and add that to the "override attr from sop" inside the rbdpackedobject. That field should contain (@active and the created attribute containing the previous activation value ---> @prev_active) then with a geometry wrangle or pop wrangle it's possivle comparing the two attributes and gather the velocity to inject only if those two attribute are not the same with a point expression. I'm interested however if there are other ways for doing that, somebody have any idea?
--Cheers Dam
Edited by Dam
@Dam:  When I was looking at the spreadsheet in the DOP network, I noticed using the active attribute that the velocity was being reset as opposed to when I didn't explicitly define that attribute and using the sop solver...
@Varishtraheja:  Not what I wanted.  The animation needs to break apart like it's being affected by wind.  Look at this:
Not sure I've understood your scene so take this with a pinch of salt. But, it looks like you're trying to transfer both the velocity attribute and the active attribute of the active object to the inactive ones. To do that I calculated the velocity on the active object using Trail SOP and then in the attribute transfer in the solver also transferred the velocity. Probably not what you meant!
test_active_velocity3.hipnc
@julian johnson
I looked at the file, it wasn't what I was looking for....for whatever reason, it's not keeping the initial velocity on the pieces when they are inactive.
I want the velocity to take off as the objects become active.  It doesn't matter whether I inherit velocity or even use the velocity on the rbd packed object to do it, it just won't do what I want.
Edited by ntkirby
@julian johnson - I saw the post here so I decided to try it.  It worked, so I went ahead and tried some other things outside of using wrangles to see what I could accomplish and I get some odd results.  I'll take a look at his H16 file and see if anything else is going on...I'll check yours too when I get home.
  • 4 months later...
On 20/9/2017 at 7:07 AM, julian johnson said:
That's a great new feature. Far less elaborate than before. So, now as long as you set the initial state to active 0 and animated 1, you can switch to active at any time, turn off animated via attribute transfer in SOPS and the objects will inherit velocity at any frame.
test_active_velocity5.hipnc
 thats an elegant solution ;)
  • 3 years later...
Hi Guys,
I am in the same situation but in a different way, the thing is my fractured pieces have constraints on it which I am breaking in dops, bringing in the velocity in thru sop is not working as it keeps on adding every frame.
How can I get the initial velocity which I am setting in sops to work in this case ?
Would really appreciate if anyone can help me with this.
Cheers
Karan
inheritVel_Test_v01.hip
  • 3 years later...
