Spiral Unrolling / Rolling Animation
yesyes
If you know VEX, you can use an attribute wrangle inside a solver. Here is a rough sketch..
Set up a (quadratic) spiral:
float rounds = (@numpt - 1) * 0.5;
float grad = 1 - ( @ptnum / float(@numpt - 1) );
float spiral = (rounds * $PI * grad);
@P.x = cos(spiral);
@P.y = sin(spiral);
@P *= grad;
Unroll the curve inside a solver:
int pt = int( ceil(@Time) );
float amount = ( radians(@Time % 1.0) * $PI * 2.5 );
matrix m = ident();
vector axis = set(0, 0, 1);
vector offset = point(0, "P", pt);
if(@ptnum > pt) {
    @P -= offset;
    rotate(m, amount, axis);
    @P *= m;
    @P += offset;
To get the wavy curve, merge it with a trail SOP running on the last point.
Useful links:
http://forums.odforce.net/topic/24056-learning-vex-via-animated-gifs-bees-bombs/
http://www.tokeru.com/cgwiki/index.php?title=The_solver_sop
Example file:
spiral_moving.hipnc
Edited by konstantin magnus
  • Thanks 2
I'd looked at this problem a few weeks ago, got 90% the way there looking at some other odforce posts, this inspired me to finish it. :)
The idea is to first calculate the angle between each curve segment, then apply it in a for each loop so each segment is rotated by the total of all the previous segment angles, at the correct pivot point.
curve_unroll.hip
  • Like 4
  • Thanks 4
