Jamshid63 Posted December 26, 2017 Share Posted December 26, 2017 Hi guys, As i have pre-roll in my simulation, i am starting my sim from 1000th frame. but this is creating a problem, when i am using the "$F" , because i know it is recognising as frame 1. so that is the help i am looking forward here. how do i fix that ?? i want this $F to be the 1000th frame not the usual first frame. if suppose, there is no solution for that , then all i want is... """i have 100 rigid pieces, and i want each frame to have different pieces staring from 1000.""". i type in piece$F in the blast node, and its starting from frame 1. Quote Link to comment Share on other sites More sharing options...
Atom Posted December 26, 2017 Share Posted December 26, 2017 (edited) There is a companion global variable called "$SF". This is the simulation frame number, Try using that instead. All frame based expressions you use inside a simulation should use $SF, not $F. Edited December 26, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 26, 2017 Share Posted December 26, 2017 1 hour ago, Atom said: There is a companion global variable called "$SF". This is the simulation frame number, Try using that instead. All frame based expressions you use inside a simulation should use $SF, not $F. so if $F is 1,2,3..... and my 'sim' substeps is say 10...does that mean $SF is 1.0, 1.1, 1.2....? Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted December 26, 2017 Share Posted December 26, 2017 11 hours ago, Jamshid63 said: """i have 100 rigid pieces, and i want each frame to have different pieces staring from 1000.""". i type in piece$F in the blast node, and its starting from frame 1. cant you do piece($F+999)? Quote Link to comment Share on other sites More sharing options...
Jamshid63 Posted December 27, 2017 Author Share Posted December 27, 2017 9 hours ago, Atom said: There is a companion global variable called "$SF". This is the simulation frame number, Try using that instead. All frame based expressions you use inside a simulation should use $SF, not $F. I tried both $SF method, and $F+999, still no good. 7 hours ago, Jesper Rahlff said: cant you do piece($F+999)? Instead tried file caching the blasted node which starts from frame 1 and used time wrap node to start from 1000th frame. it works. But i am sure, there must be an easy way. i have attached the .hip file , in case if you guys didnt understand what i am trying to say . framestart_problem.hipnc Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 27, 2017 Share Posted December 27, 2017 (edited) here...so you see in my Blast...if I start at frame 100, I put in -99 in your case put in -999 So if you want the one piece to be NOT deleted and blast the rest..then of course simply put a ! infront, ie. !@name==`piece+($F-999)` (oh..of course, delete non-selected too....silly me) deletePiece.hipnc Edited December 27, 2017 by Noobini Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 27, 2017 Share Posted December 27, 2017 (edited) I modded your file, scrub from frame 1000 to see, I'm not sure if your setup is right tho...you've got debris, then you've also got class...you might wanna tweak a bit.... EDIT: added a switch in so all is there up to 999, then it starts blasting... framestart_problem_mod.hipnc Edited December 27, 2017 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
Jamshid63 Posted January 2, 2018 Author Share Posted January 2, 2018 Thanks alot. Quote Link to comment Share on other sites More sharing options...
