art3mis Posted February 20, 2018 Share Posted February 20, 2018 (edited) Hi Am I correct in assuming that NO FBX export options exist for Indie users? Is there any other way to export an animated mesh without having to purchase a full FX license? There is no mention of export limitations under the feature comparison chart for File Formats https://www.sidefx.com/filmtv/compare/ Edited February 20, 2018 by art3mis Quote Link to comment Share on other sites More sharing options...
stickman Posted February 20, 2018 Share Posted February 20, 2018 There are no FBX export for NC - Noncommercial (Apprentice). As the chart you link to says, you can export from indie. Quote Link to comment Share on other sites More sharing options...
art3mis Posted February 20, 2018 Author Share Posted February 20, 2018 (edited) Thanks. Yes, apparently you are correct. Was mislead by the error message generated Quote "FBX export is only supported in Houdini Core and Houdini FX" Edited February 20, 2018 by art3mis Quote Link to comment Share on other sites More sharing options...
lavitz01 Posted February 20, 2018 Share Posted February 20, 2018 He has indie which I believe does export. I believe he can export as FBX or alembic (.abc). I believe the only limitation of indie is that it has a rendering limitation of 1280 x 720 with no watermark. Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 21, 2018 Share Posted February 21, 2018 (edited) Houdini indie it allows you to render 4K since version 16.5.378 just in case and before that was 1080P for animations, stills was unlimited. More info here https://www.sidefx.com/community/production-build-update-165378/ Edited February 21, 2018 by Sepu Quote Link to comment Share on other sites More sharing options...
art3mis Posted February 22, 2018 Author Share Posted February 22, 2018 yep, thanks. SideFX needs to update their error messages:) Quote Link to comment Share on other sites More sharing options...
