Remove Primitive by Sphere
CinnamonMetal
if(@primnum>45){
vector ghh = point(1,"P",i);
removeprim(0,ghh,1);
I'm hoping I can get some help.
*ghh* is a variable which represents a sphere.  What I want is, when moving the sphere around if it should come in contact with primitives with numbers greater then 45 then it removes those primitives; although it's not working, what am I doing wrong ?
Is your sphre (the « trigger » object) a simple primitive (therefore only one point), or is it polygon sphres, with many points ?
What you can do is use the xyzdist vex function to calculate, for each point or primitive of your object, the closest distance to the sphere, and when it reaches a threshold close to zero (ie. When there is contact), you use removeprim.
But this is very similar to the use of the trasnfer attribute and grouping method explained above.
This should work:
// Get distance of primitive to point position of second input, Sphere is plugged in to second input //
float dist = distance(@P, point(1, "P", 0));
// Get radius of sphere, I made a relative reference to the spheres scale in the radius parameter that is created //
float rad = chf("radius");
// If the primitive is inside the sphere, delete//
if(dist<=rad){
	removeprim(0, @primnum, 1);
Edited by Sean-R
Fixed code error
