Which node breaks a geometry into primitives using an attribute ?
AntoineSfx
I'm trying to do: grid -> cluster ->  create one primitive per group of points with the same cluster value
It must be trivial but I can't find the node / checkbox somewhere that does this thing..
Edited by AntoineSfx
  • 2 weeks later...
you may also try promoting the attributes to vertex attribs, and then applying a vertexSplit node, if you actually need to split the primiitives (so you could use a connectivity sop later for instance)
also continuing from 3Dome, you could also do both in one node:
string grp = sprintf("cluster_%d", i@cluster);
setprimgroup(0, grp, @primnum, 1);
