Channel parameter from a variable
Hello!
I'm trying to create a channel parameter but with the exception that I want it's input or it's value to be driven by a variable & not a user input/slider.
Am I even going about it the right way? I just want to get my variable (it's just a float) out of the vex wrangle and on to the UI at the bottom. So basically the opposite of pumping a value into a wrangle. Is this even doable?
Channel_Parameter_from_variable.hipnc
I don't think VEX can write to channel parameters yet. It can read from them. However, python can. If that is your goal, alter your code to use python instead.
n = hou.node("/obj/my_node")
n.parm("my_display_parm").set(my_value)
Edited by Atom
  • Thanks 1
That's a bummer :| I was planning on using the output to drive parameters on other nodes (copy/paste relative reference etc..)
I don't know anything about python... just learning vex is daunting enough for a non-programmer lol. But it's good to know that the functionality is missing at the moment.
Does SESI have any plans to add it? Something like:   ochf("parametername", myvariable);      to output a float channel would be nice :s
Anything you want to do by "setting a parameter" can be done with attributes. You could store your value as a detail attribute then fetch that value using a detail expression. It would basically be the same as fetching a value using a relative reference expression.
@AtomIs this the same as putting a expression variable inside a string expression which the user can then enter some text (string of characters) ? For example, suppose you have a expression variable $SuperDuper when using that expression variable, the user is then prompt for some text, and so the text entered by the user, replaces the expression variable ?
No, it's not like that. Detail is just a global storage area on a node. So it is not point based, vertex based or primitive based. If you want to store a value associated with a node, you can place it in the Details attribute context of the node.
  • 1 year later...
ok this is a year late, however  I have issues trying to set a param value on a switch sop higher up the chain. For some reason it does not obey the set value. Same applies for an attribute. You cannot set the attribute to update earlier in the chain ( for eg driving a switch ).  Not sure how to automate this.
  • 1 year later...
@oblongdid you solve the problem of setting a switch node index upstream?
