Can someone please help me with this fire effect in houdini
voxelini
hello guys,
im working on a project for which i need to recreate this look in houdini
i would really appreciate if some could help me figure out how to do the cape effect
im kinda new to houdini and stuck at this effect..
working on a deadline please help out as soon as you can if possible
thank you :)
I Imagine its a combination of some nice burning shader work on the cape material itself.
Then combined with some pyro/sparks.
- So I would approach it in this order; (Simplified)
- Create your noise/mask attribute for burning on the geometry you wish to be burning, pump this attribute into the shader and then do some magic to create the burning look.
- Use this same attribute to emit both your pyro and sparks. Or create your pyro which drives your sparks.
- Iterate until it all works together nicely.
Hope this helps :)
As people above have mentioned the tasks involved in making a shot like this to work, is a team work , fx, lighting, comp and grading to get something like this done ,
but do not get discouraged, you can always try making something similar if time and resources are a constraint, so quickly put together a hip file , so you can play around with and modify to your needs ,
and there is a post related this topic in the effects forum, lava flow, so you can refer to that as well ,
clothsetup.hiplc
  • Thanks 1
