Alexandre Posted November 22, 2018 Share Posted November 22, 2018 Hello everyone ! I can't figure out how to copy the attribute pscale (from a wrangle) onto a sphere... I am sure I am missing something because it should be straightforward see attached figure Thanks and sorry for the low level question Quote Link to comment Share on other sites More sharing options...
Alexandre Posted November 22, 2018 Author Share Posted November 22, 2018 I have written: float @pscale =5; instead of f@pscale =5; now it appears as so in geometry spreadsheet (instead of 0.0) but there is no impact on sphere scale when changing pscale in the wrangle node... Quote Link to comment Share on other sites More sharing options...
tamagochy Posted November 22, 2018 Share Posted November 22, 2018 (edited) plug sphere to point wrangle and wright f@pscale=5.0; you no need copy for it if you want copy attribute from another geo to sphere you should use attribute transfer Edited November 22, 2018 by tamagochy Quote Link to comment Share on other sites More sharing options...
3dome Posted November 22, 2018 Share Posted November 22, 2018 you will not see a change in size! if you want to see a change, create a point (add sop), wrangle a pscale of e.g 5.0 onto that point and use a copyToPoints sop to copy your sphere onto that point but for all those simple and basic stuff (and later more) you should consult @mestela's amazing wiki http://www.tokeru.com/cgwiki/ Quote Link to comment Share on other sites More sharing options...
Alexandre Posted November 22, 2018 Author Share Posted November 22, 2018 Thanks it works ! yeah I am currently learning VEX, thanks to cgwiki, entagma, houdini help, google and odforce forum coming from matlab (matrix) for data processing Quote Link to comment Share on other sites More sharing options...
