Organizing complex assets
kiryha
I have a complex HDA (a city) where all parts were merged together from a bunch of miscellaneous caches. I use HDA to transfer data between production stages, to load environment model in render scenes. At some point, I was not able to render my scene, after the "Generate scene..." message nothing happened for quite a long time. So I start to troubleshoot all this mess and find some possible reasons for issues.
First, I have static geo (terrain, buildings etc) and animated parts (moving cars, peoples etc) merged together and I add a Trail sop to calculate velocity to get motion blur at the end of my network (after all merges). I delete this node and scene start rendering again. So the first conclusion I made: I can't merge static and animated geometry, have to create separate HDA for moving parts.
After this, I stuck with the next issue, some parts of the asset were not present on render, some of them were black... I clean up all attributes on all caches, leave the only shop_materialpath and this helps, I get what I expected on render. So my second conclusion: merged objects have to share the same attributes to work properly.
My question is: do my conclusions make sense? I doubt cos until some point the all-in-one messy asset were rendered fine... I realize that this is quite an abstract question but I have a filling I might do something wrong at the high level.
I don't know how to share the HDA, cos all geometry is baked on disk and its a lot of data. Here is collapsed asset, just for reference of HDA structure GEO_CITY_030.hipnc And example render of the environment.
Quote
There's an option to save asset definition inside the hipfile. Assets >> Asset Manager .. [ Configuration ] Save Operators definitions to Hip File.
For geo, you could use a 'stash' sop node or lock the node.
It's a bit difficult to visualize possible problems without seeing the geometry. Looking through your scene everything looks fine. There are many ways to solve complex scenes and this will depend a lot on the challenges you face to output and which control you're looking for.
Well, after I sort out all attributes (now they are all the same for all merge nodes) and split animated data into a separate asset the scene is rendering fine.
Next, I will try to merge animation back to the main asset, see what will happen. In overall, the question was if its ok to merge branches with mismatched attributes...
but if your cars are moving/animated....I don't think you're using stash correctly. If you feed something to stash, click Stash Input, then it takes a snapshot at that instant....it's not storing the entire sequence/animation of whatever you're feeding it...
an extremely easy test to do, animate a ball going left to right, then add stash, test Stash at various different frames and you'll see the effect immediately.
Edited by Noobini
it should i guess..here I'm testing stashing a mix of packed/nonpacked geos...seems to be fine..
it doesn't explain why I can't see anything in your stash tho...even tho it says there are 462 packed geos...i can't see anything...maybe to be sure...click stash input again before you save and upload..
3 hours ago, kiryha said:
I extract nodes from asset and delete it. Even so, the issue still exists, rendering does not starts. If you turn OFF the "Geometry Velocity Blur" on ENVIRONMENT node it will work.
E010_S040_0081.zip
No, all the same.
then i tried render MONUMENT geometry and got this
and when i unpacked
It seems that something wrong with your alembic.
Now:
MONUMENT - render OK
I pulled alembic form ABC.zip into the scene - render OK
copy to point alembic, pack and instance - on - render OK
then merge this packed geos and MONUMENT - render OK
merge alembic and MONUMENT - render OK
I did this with and without stash node - all OK
But from TRAFFIC i can't see anything
Now I've tried this:
saved scene with merged alembic and geo from MONUMENT and stash. Then i delete alembic files from the disk and opened scene again. And that why i can't see alembic because it must be on the disk even if using stash node or locking node. No one alembic geometry in viewport and Render View. When I've returned *.abc on the disk  - all OK.
Edited by vicvvsh
Here are the source vehicles (I have no idea how to use them cos they were copied to points and then baked to bgeo.sc which was unpack and stashed). I think even if you will get all the data to render it may not reproduce my problem...
I wonder, if there are any tools to collect all data for Houdini scene so I can share the necessary part as is, without any baking and collapsing (cos during this stages we can loose the reason of issue).
VEHICLES.zip
Yes, I ended up separating animated and static data and everything is working fine since. It makes setup a bit more complex, you have to carry two environments HDA instead of one but its still manageable.
I think there should be a way to put everything in one HDA but for now, I will move forward with this solution.
