Draw polyline from a single point to multiple points
Hello!
I'm messing around with bullet constraint networks and I can't figure out how to connect a bunch of points to a single point... basically one source point and multiple paths from it towards each packed piece. Connect adjacent node doesn't have this behaviour.
The idea is to connect a fractured packed geo with many points/parts to a non fractured packed geo that has just 1 point/part. I know this will requre some kind of wrangle & coding is not my strong point :| ... any help woud be appreciated! Thank you for your time I appreciate it!
Attatched a simple scene, it's just missing the 2nd constraint network.
polyline_constaint.hipnc
Thank you Noobini :D
The new constraint works in dops but it doesn't behave as expected... but regardless, that's a different problem.
I mostly just wanted to know how to go about connecting 1 source point to many points and both your example are very helpful!
Sepu: Also very helpful! Thank you guys!!
