Frozen Volume using Upres node
HM_2020
On 1/23/2019 at 7:19 PM, pusat said:
This is volume accumulation, you can do it inside a solver sop, with volume mix using Max mix method, but you have to make sure to resize your volume each frame as you go.
Yes, why doing it in Upres is a little easier, it just resizes, upresezzzz, and tweak things "live" a bit more. :D
Edited by HowardM
